replacing the fuel pump - JeepForum.com
post #1 of 2 Old 10-05-2003, 03:22 PM Thread Starter
AK1904
well it turns out i need a new fuel pump ...so i put one on order and i was wondering if any one knows how to or has replaced a fuel pump on a 90 wrangler i know that the fuel pump is the fuel tank which is a pain but i was hoping that i would be able to do it my self instead of having them do it for me.....any help on this subject or input would be great
AK1904 is offline
post #2 of 2 Old 10-05-2003, 07:50 PM
igotdoo
Disconnect negative battery terminal. We are working with fuel and electrical here.
Pull tank: 4 nuts in the back, 3 in the front. Pray the rear bolts (carriage bolts) dont spin, meaning you have to cut them off (I did)
Lower tank carefully, and disconnect output, return, fill, filler vent, and vent hoses. Disconnect electrical connector.
Pull tank fully out. Depending on your tank, you might have slightly different lock ring type mechanisms to remove sending unit.
Remove sending unit assembly. Pump is easily replaced now. Install NEW fuel pickup/filter screen. Take care inserting assembly back into tank, as it is easy to knock of screen, or bend fuel sending unit arm.
Install NEW o-ring seal for fuel tank, no matter how good yours looks. Pulling a tank twice is a real drag.
Reconnect. Take not that the fuel output and return lines are different sizes, and you need to get this right. Mark them before removal if you arent 100% sure on these.
Install nuts and tighten. Cross fingers, say a prayer, and connect battery terminal back up.
igotdoo is offline
strange method of replacing fuel pump The_Aaron TJ Wrangler Technical Forum 26 01-25-2010 08:42 PM
Replacing FUEL PUMP this week , any tips that will help a newbie? chaznad TJ Wrangler Technical Forum 5 04-01-2009 11:10 AM
replacing fuel pump on YJ parpac316 YJ Wrangler Technical Forum 12 07-28-2008 09:01 AM
Replacing fuel pump pasinbuy YJ Wrangler Technical Forum 2 04-16-2008 08:31 PM
it's 12:45am and in 7 hours i am replacing my fuel pump j-man YJ Wrangler Technical Forum 3 10-01-2005 09:43 PM
