Replacing fuel pump - JeepForum.com
post #1 of 10 Old 04-20-2010, 06:58 PM Thread Starter
CapeCodGuy
Replacing fuel pump
Im about to replace the fuel pump in my 89 4.2. Its the first thing besides oil, tires, lights and fuses that Ive replaced in a vehicle. Is it at straight forward as it seems? I searched for a write up but couldnt find one. The only one I found was for an in tank pump. Any pointers or guidance would be great before I blow myself up! Thanks
CapeCodGuy is offline
post #2 of 10 Old 04-21-2010, 05:16 PM Thread Starter
CapeCodGuy
Well, I got it out, but cant get the new one in. Not sure where to go. I feel like I should just force it in there, but Im afraid Im going to break or screw something up.
post #3 of 10 Old 04-21-2010, 05:31 PM
monkeyhouse
It's pretty easy, disconnect the negative battery cable, remove the cap from the gas tank, wrap towels around the fuel pump hoses and disconnect them, remove the two mounting bolts, clean up the gasket area. Installation is the opposite. Here are some posts to a thread about the same subject, should help ya out!
if you bump the motor around you can get the fule pump cam on it's lowest spot and the pump will be a lot easer to put on
it helps to have someone else there to put the bolts in. took me 20 minutes of messing with it to get it in. dont forget the gasket either. i did and had to do it again.
Replacing the fuel pump is extremely easy...I am no mechanic and i found the hardest part is aligning the new pump into the engine block. I found mine at NAPA autostore
Uh about two bolts hold it on plus the associated lines.... On a scale of 1 - 10 it's about a 2 on the difficulty scale....
Here is a link to the best info I could find if you've never done this kind of work before, actually pretty good considering it's free:
http://www.autozone.com/servlet/UiBr...raseCrumbs=YES
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #4 of 10 Old 04-21-2010, 07:42 PM Thread Starter
CapeCodGuy
Thanks. Getting it off was easy, except for the bolt that holds the fuel line to the pump was completely siezed. I had to disconnect from the fuel filter and take it all off as one piece. It slid out so easy I figured it would go back in just as easy. I got mad and took a break. Ill go at it again soon enough. Thanks for the info!
post #5 of 10 Old 04-21-2010, 08:35 PM
stickfight
It helps to tilt the arm of the pump up as you insert it. Get the base of the pump close enough to the block for the bolts to engage a few threads, then use them to pull it the rest of the way to the block.
Because of the way the arm engages the lobe inside the block it tends to push the pump away from the block.
stickfight is offline
post #6 of 10 Old 04-21-2010, 08:44 PM Thread Starter
CapeCodGuy
Thanks. All the tips are a huge help. Im nervous Im going to damage something internal, so once I get resistance I stop jamming. Somethings just arent meant to be jammed!
post #7 of 10 Old 04-22-2010, 08:33 AM
xdgt03
Yeah, you have to rotate the crank (by the bolt in the center of the crank pulley and much easier if you remove a spark plug or two first) until the lobe the fuel pump arm rides on is at its highest spot (not pushing on the pump arm) If you don't do this you can break the ear (tab the mounting bolts goes through) off the pump when you install the new one. This will really make you mad. Ask me how I know. lol
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #8 of 10 Old 04-22-2010, 12:13 PM Thread Starter
CapeCodGuy
Thanks for the tip. Im going to be re-attacking it again after work. Forgive my ignorance but, why is it easier to rotate the crank after the plug removal? Any ones in particular?
post #9 of 10 Old 04-22-2010, 12:48 PM
88YJtoCJ
allows the compression to blow out of the plug hole, instead of working against you.
Anytime I turn a motor over by hand, I disconnect the Coil wire, but as we have already disconnected the battery cable, you will be fine.
88YJtoCJ
White 88 YJ = $2000
Straight 6 = $1200
AX15 = $400
Sagging Springs = Priceless
88YJtoCJ is offline
post #10 of 10 Old 04-22-2010, 07:33 PM Thread Starter
CapeCodGuy
Venting now....WHY IS THIS SUCH A PAIN IN THE ***!?!?!?!?! One would think the old one came out so easy, why wont the new one just slip in? Ive cranked the engine over and still nothing, doesnt feel like Im making any progress at all, it seems like the pump arm hits at the same place no matter what. If I could get this dam thing running Id drive it into a lake!!!! OK, rant over
strange method of replacing fuel pump The_Aaron TJ Wrangler Technical Forum 26 01-25-2010 09:42 PM
replacing fuel pump on YJ parpac316 YJ Wrangler Technical Forum 12 07-28-2008 10:01 AM
Replacing fuel pump pasinbuy YJ Wrangler Technical Forum 2 04-16-2008 09:31 PM
it's 12:45am and in 7 hours i am replacing my fuel pump j-man YJ Wrangler Technical Forum 3 10-01-2005 10:43 PM
replacing the fuel pump AK1904 YJ Wrangler Technical Forum 1 10-05-2003 08:50 PM
