Replacing distributor cap and rotor... different design? - JeepForum.com
post #1 of 17 Old 02-08-2010, 10:00 AM Thread Starter
XJelvis
We finally had a sunny day last week with temps above 30, so I got to work on installing the Crown tune up kit for my 94 YJ.
When I was putting the rotor on, I noticed the new one was a different design than what was already on there. The original one had a tab to keep it from sliding around, and the new one lacks that tab. Also, the new one doesn't fit as snugly on the post/shaft.
I'm no engine expert, so I left the original one in place. It looked to be much better quality. What do you think, is the new one fine or is it the wrong part?
(The gray one was on there, the black one is the new one from the kit.)
94 YJ, 2.5L, 5sp Sold.
97 TJ, 4.0, 5sp Sold.
01 XJ, 4.0, Auto
XJelvis is offline
post #2 of 17 Old 02-08-2010, 10:16 AM
baddkarmaracing
i just changed mine and the original (i think) and the new one were identical to the black one
95 YJ: all stock :( many things coming though. any suggestions ???
04 Ford F-250: 35's, tuned, exhaust, intake. <==== it runs pretty good hehe
baddkarmaracing is offline
post #3 of 17 Old 02-08-2010, 10:25 AM
sdowney717
if it is not broke then
whats wrong with the old one, nothing.
sdowney717 is offline
post #4 of 17 Old 02-08-2010, 10:37 AM
moonshinefuel
It is the wrong part, that's all. There are two different designs. Happens to me sometimes, they will always get the cap right, but there were 2 different designs for the rotors.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #5 of 17 Old 02-08-2010, 11:25 AM Thread Starter
XJelvis
The YJ is new to me so I'm just going through replacing things
01 XJ, 4.0, Auto
XJelvis is offline
post #6 of 17 Old 02-08-2010, 11:26 AM Thread Starter
XJelvis
You think Quadratec would send me the other design if I asked? The gray one is actually the one pictured on their site in the 94-95 kit. No biggie though, it's working fine.
Thanks for the replies
01 XJ, 4.0, Auto
XJelvis is offline
post #7 of 17 Old 03-27-2010, 06:11 PM
tkwok
I just purchased a new rotor from my local Kragen and it looks like the grey one on the right. The one that is currently in my Jeep looks like the black one on the left. I double checked the parts number on kragen's website and it matches the one I purchased. Any ideas?
tkwok is offline
post #8 of 17 Old 03-27-2010, 06:20 PM
Neo1130
2015 JK Wrangler
It's called "preventative maintenance."
Neo1130 is offline
post #9 of 17 Old 03-28-2010, 09:48 AM
95 Lowbuck
I've got a 95 with a 2.5, bought a crown kit and had the same problem.
Had to buy it from a dealer about an hour and a half away and had it shipped.
Mine ended up being the black one so I bought matching Cap and Rotor locally.
Which is the way they should be bought becuase if you look real close,
at the end of the rotors, it does not have the same sweeping radius.
It will create an incorrect gap between the Cap and Rotor if not
bought in sets.
The crappy part of this whole story is nethier the dealer or crown
made any attempt to investigate or fix this problem when contacted.
95 Lowbuck is offline
post #10 of 17 Old 03-28-2010, 04:35 PM Thread Starter
XJelvis
I'd use it. At least in my Jeep, that style fits so much better and is sturdier. Who knows, maybe the one in there now was a crappy one from the Crown tune up kit installed by a previous owner?
01 XJ, 4.0, Auto
XJelvis is offline
post #11 of 17 Old 03-28-2010, 05:24 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
There are two different type of distributers used on YJ's One type I believe is nippon denso and then there is another type. It may be on a laberl on the side of the distributer. The rotor and caps are not intechangable. Support your local parts store for these items and avoid all the delays and problems.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #12 of 17 Old 03-28-2010, 06:09 PM Thread Starter
XJelvis
bought in sets.
This is how I'll be doing it from now on
01 XJ, 4.0, Auto
XJelvis is offline
post #13 of 17 Old 03-29-2010, 08:56 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Since you are performing maintenance on your ignition system, I would recommend that you look into the Team Rush mod, this basically replaces your stock coil with a more powerful one and your distributor cap, rotor and wires with larger, better quality parts.
I would not recommend using those black rotors and caps, I have learned from a very reliable source that those contain carbon ( to make them black ) which is conductive and leads to misfires and spark problems.
I believe all YJ owners should do the Team Rush mod, the stock ignition system on our Jeeps is extremely limited and even if you install all new parts, will never perform as good as with the Team Rush, just my two cents!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #14 of 17 Old 03-29-2010, 09:06 AM
planedog
My '94 has the black rotor type and the '93 core engine I bought had the gray rotor type sensor. The only difference is in the way the cam sensor is mounted. The later distributor (black) has the hall effect sensor mounted on a piece of flimsy plastic right under the cap. When inspecting my '94 (black) I noticed that the sensor had been rubbing the metal ring (mounted to the shaft, the part that moves through the sensor) which I attribute to the plastic mounting plate deforming with age.
I have decided to go back with the '93 (gray) because it is mounted more securely. The main advantage of the '94 (black) is that you would not have to remove the dist to replace the sensor but that is a minor convenience for me, i like the rugged way the '93 (gray) is designed, there is no way for the sensor to move.
planedog is offline
post #15 of 17 Old 03-29-2010, 09:20 AM
dan240
dan240's Avatar
Team Rush mod for a 4.0 liter? I think that's only for the 4.2
1994 YJ 4.0L 5spd
SOA, 5100 Bilstein, TJ Flares, 35" BFG AT, 8.8, SYE, D30 truetrac/chromo, 1" MML
dan240 is offline
Stuck Rotor Button on Distributor Shaft cdrymalla TJ Wrangler Technical Forum 1 12-06-2009 11:43 AM
Distributor Cap/Rotor/Spark Plugs/Wire Set digizure YJ Wrangler Technical Forum 7 06-29-2009 08:43 PM
Should i get a new Distributor Cap & Rotor and wires Movie included Micah1234 YJ Wrangler Technical Forum 6 06-13-2008 10:20 PM
distributor cap and rotor DirtyJeep95 YJ Wrangler Technical Forum 4 12-04-2007 04:47 PM
distributor cap and rotor dr_phatcity TJ Wrangler Technical Forum 3 08-04-2005 07:32 PM
