replacing clutch slave cylinder 93 4.0 - JeepForum.com
post #1 of 7 Old 06-29-2009, 09:29 PM Thread Starter
Nate M
Hey guys I have no pressure after my jeep sits for ten or twenty minutes now in my clutch pedal...I can pump the pedal and get the clutch pedal back but it is leaking fluid which I cannot see so I am quiete positive it is the slave cylinder...what is envolved in this repair?
Nate
98 TJ sport 4.0 manual 3"BL (I did not put it on) 35 12.5 MTR
Nate M is offline
post #2 of 7 Old 06-29-2009, 10:27 PM
MJMPC
Pull your carpet and see if the master is leaking in the cab under the clutch pedal...........
http://www.jeepforum.com/forum/f12/clutch-master-cylinder-replacement-728960/
Just found this
its what I was talking about.............
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 7 Old 06-30-2009, 07:34 AM Thread Starter
Nate M
I sure hope it is the master but in the case that it is the slave has anyone done this repair?
Nate M is offline
post #4 of 7 Old 06-30-2009, 10:00 AM
Leans93
She's my density...
Leans93's Avatar
If it is your slave and it is stock then you will need to drop the transmission as the 93' came with the internal slave.
Once you drop the tranny you just take the old slave out and put the new one in. That part of the job is fairly easy.
If your clutch is old or original you may want to put a new clutch in there while you're at it. They sell clutch kits such as LUK which comes with a new slave clutch pressure plate and all the goodies you will need.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #5 of 7 Old 06-30-2009, 10:13 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
And here's a pic of the old slave still installed on my AX-15 right after I pulled it out.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 7 Old 06-30-2009, 08:53 PM Thread Starter
Nate M
well I think I may get lucky and it is the master cylinder that is bad. I actually work in sales for the largest spring pin manufacturer in the world and original designer of the coiled spring pin, Spirol International.
I am going to get a new master cylinder and replace the one I have and see if I can get the bleeder off the slave end of the system. I will start hitting the bleeder with PB now while I wait for the Master Cylinder to arrive.
Thanks for your help guys and I will keep you posted on the progress.
Nate
Nate M is offline
post #7 of 7 Old 07-02-2009, 08:53 AM Thread Starter
Nate M
so I replaced the Clutch M/C last night after work and sure enough looks like the tiny little 1/4 inch bleeder for the slave cylinder is not going to open up for me.
I noticed that the bleeder is threaded into a larger cap which the line coming out of the bell housing threads into...I think this is hopefully a part which I can replace??? Maybe it comes with a new bleeder too?
I am going to look into it but this should hopefully work because even after I pumped the pedal for five minutes I still had next to no fluid movement or pedal feel so I am thinking it needs to be bled bad.
Nate
Nate M is offline
Replacing slave cylinder on 4cyl. YJ JayIV YJ Wrangler Technical Forum 7 05-14-2012 01:35 PM
Replacing Slave Cylinder bcshome YJ Wrangler Technical Forum 19 02-16-2009 12:42 AM
Replacing the Slave Cylinder - master too? Duncan71 YJ Wrangler Technical Forum 13 07-28-2008 02:23 PM
Should I replace the slave cylinder when replacing the clutch? Mark_ZZ3 YJ Wrangler Technical Forum 6 07-04-2006 08:15 AM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 09:37 AM
