Replacing Clutch, and Slave Cylinder - JeepForum.com
post #1 of 12 Old 06-27-2013, 12:57 AM Thread Starter
secrethojo
This weekend I am replacing my clutch and slave cylinder, Its a 1990 YJ, I am just curious as to if there is anything i should expect to run into while doing this?
secrethojo is offline
post #2 of 12 Old 06-27-2013, 02:54 AM
AmmitOsiris
It's a YJ, expect the unexpected.....(insert creepy laugh here)
AmmitOsiris is offline
post #3 of 12 Old 06-27-2013, 02:56 AM Thread Starter
secrethojo
yes thats why I was posting hoping that maybe people have encountered a common problem. But i will post Saturday night about how it all went!
post #4 of 12 Old 06-27-2013, 09:47 AM
jokerchief462
While you have the tranny and T-Case out you may want to put new seals in the cases. Tranny out put T-Case input and out put, check your u-joints while the shaft is down and the rear pinion seal.
Some time cleaning up all the parts and may be some spray bomb would go a long way. You can also address any frame corrosion in that area and tidy that up also.
While your down take a look down the drivers frame rail and inspect your brake and fuel lines and see what kind of health they are in may be some future work there.
Thats enough to keep someone busy for a week.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 12 Old 06-27-2013, 10:04 AM
GrantYJ
Be very, very careful when you're removing and installing the slave cylinder hydraulic line. The line coming from your clutch MC is a small plastic line and the fitting where you disconnect the slave is very easy to damage. If damaged, you'll end up with a continuous leak and it's very difficult to find replacements.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #6 of 12 Old 06-27-2013, 04:33 PM Thread Starter
secrethojo
Thank you for you're inputs I start the project tomorrow evening removing everything, As i need my parents garage to do so, All my stuff is in storage, i will post photos of everything up for everyone to see
post #7 of 12 Old 06-27-2013, 06:43 PM
bigbossd1030
I suggest a pilot bearing puller. Makes the job real easy and is normally free to rent. Also there should be an inverted torx bolt at the top of the transmission bell housing, E6 torx socket, swivels and extensions are good to have while removing this bolt. Replace with a 6 point bolt if possible.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #8 of 12 Old 06-28-2013, 12:22 AM
gtg413i
2003 WJ
Keep going and replace thetiming chain as well.
Brian's Black Betty Build:
gtg413i is offline
post #9 of 12 Old 06-28-2013, 06:47 AM
bigbossd1030
Okay guys, he is doing a clutch job, not a complete overhaul lol. At this rate you might as well take the body off and do a rebuild on everything.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #10 of 12 Old 06-30-2013, 12:20 PM Thread Starter
secrethojo
To to give an update, finished it last night, There were a number of things that were done Incorrectly before, that i had to go in and change, My only question is that on other peoples YJ, Is that skid plate the support for the transmission? I feel like it puts a huge stress on the whole system, if you like i can upload photos to show what i am describing, But overall 2days of working in 105 Degree weather in Sunny San Diego it went together, I replaced the Master Cylinder as it wasnt allowing for bleeding of the lines at the end did a last min autozone run, Next quest is to fix the exhaust system on it, in a couple weeks. My yj really reminds me of a women, its never happy, always complains but at the end of the day, You treat her as royilty no matter how much Bull ***** you get put through or am i the only one who feels that way? Anyway, feel free to PM me with questions or comments anytime!
post #11 of 12 Old 06-30-2013, 01:07 PM
dancytron
Yes, the skid plate is the only support for the transmission. http://www.jeepforum.com/forum/f12/t...cement-903109/
dancytron is offline
post #12 of 12 Old 06-30-2013, 01:12 PM
bigbossd1030
The skid plate does indeed support the transmission. The reason you feel in puts strain on the system is because the engine pivots on the engine mounts, so when you put up the skid plate, you are in turn, lifting the back portion of the engine, transmission and transfer case. Yup, very similar to a woman, minus a few things that women can do for you.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
clutch issue , jeep
