Replacing Clutch Master Cylinder Line - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Replacing Clutch Master Cylinder Line
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 02-08-2009, 06:05 PM   #1
Turco
I have a 1993 Jeep Wrangler YJ. I recently replaced the clutch master cylinder (among other things), and I'm having trouble getting the line going from the slave to the master on the fitting, on the clutch master. There's this hard molded plastic line that I can't seem to get over the "nipple".
Does anyone know of a replacement line...Something more flexible?
The fitting that's in the clutch master cylinder is like a push compression fitting that you lock in place with a set-pin and it's barbed..
Turco is offline   Reply With Quote
Unread 02-08-2009, 07:11 PM   #2
Opihi59
from here it gets rough
Opihi59's Avatar
http://www.jeepforum.com/forum/showt...ht=clutch+hose
Try this link, there are replacements available, there is a link in the thread link posted above that will lead you to a fitting from Advanced Adaptors. In addition if you search the forum "clutch hose" etc you may find other threads. Someone did a writeup within the last 6 months on a complete hose mod to get rid of the quick connect. I ended up converting my clutch slave from an internal to external type and just bypassed the issue completely that way.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline   Reply With Quote
