Which replacement steering shaft to get? - JeepForum.com
post #1 of 3 Old 01-21-2010, 02:35 PM Thread Starter
brunolinski
89 YJ: I am replacing my steering shaft b/c mine has developed some play and it is not as safe as it could be.
I know I can get a new one from dozens of vendor websites, but I am not sure which one I want. If you have replaced your steering shaft, please let me know the following:
what brand do you have:
when did you get it:
where did you purchase it:
ARE YOU HAPPY WITH IT?
thanks!
B
brunolinski is offline
post #2 of 3 Old 01-21-2010, 03:10 PM
ritjobbie
I've had the Borgeson shaft in my YJ for about a year now. Noticeably less slop and vibration in my steering, but then again my old shaft was toast. Joints were bad and the slip joint was frooooozen solid.
It's a really nice heavy piece of steel. It'll definitely outlast my Jeep. Rubber boot over the slip joint. Splines were really tight on my column and Durango box. Really nice fit. The slip joint is kinda' hard to get moving, but this is only really a problem during installation. It'll move just fine when you smash into a tree.
With steering and brakes, you really can't skimp, IMO. Safety first.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #3 of 3 Old 01-21-2010, 03:14 PM
jbolty
jbolty's Avatar
jc whitney. $99. 2 years and no issues.
jbolty is offline
Lower Steering shaft replacement EnFuegoUno YJ Wrangler Technical Forum 14 10-24-2009 07:15 AM
Replacement Steering Shaft Doesn't Telescope? cmsurfer YJ Wrangler Technical Forum 11 09-25-2009 10:29 AM
is there a replacement u-joint for the steering shaft mymizzery YJ Wrangler Technical Forum 5 08-01-2009 05:19 AM
Steering Shaft and Bearing Replacement ech0sh4y YJ Wrangler Technical Forum 6 11-18-2008 09:09 PM
Steering Shaft Replacement wolf3902 YJ Wrangler Technical Forum 6 07-07-2005 09:24 PM
