Replacement seats, Post up what year/model you used
| Truck-Lite's New LED Headlamp Series | Ruffstuff Axle Simple Swap Kit! | Spartan Lockers FREE SHIPPING Excellent Prices |
#1 | |
Got my eye on you.....
Ok, so after the many, many........Seat swap posts lately, I decided to take some time and compile a list of what seats are direct bolt in and what seats will fit with MINOR modifications.
SO, post up what you ACTUALLY used, not what you have heard fits and what it took to make them fit if some fab work was required. This list will be submitted to TombRaider for final approval and then be stickied. (If that is allright with you of course Tomb...) LIST MOVED TO JEEPWIKI ARTICLE : http://www.jeepforum.com/wiki/index.php/CJ/YJ_Seat_swaps
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 Last edited by rustywrangler; 12-11-2007 at 09:44 PM.. |
#2 |
I installed a set of leather power seats from a 1997 Eddie Bauer Edition Ford Explorer. Wasn't a straight swap, but it only required a little fabrication. I even hooked up the power!! I'll send a link when I get a picture.
#3 |
Here is a quick pic I found.
Phil ![]() |
#4 | |
Care to make a small writeup for that???? How hard was it, welding required, etc.???? ![]()
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#5 |
I put in seats from a mid 90's grand am i had to weld a piece off flat bar on the existing mounts of the seat to make the sliders attach to the stock yj seat bracket. it took me approx half an hour and i can say it was definately worth it
89 YJ, Chevy 350, 5.7L Edelbrock: 600cfm 4 barrel carb, Performer series intake Signature air cleaner, Signature Tall valve covers FlowTech: Shorty headers, Dual Glass Pack Mufflers My [url="http://www.rigrater.com"]RigRater[/url] Score: 545RRv1.0 with a BOA of 29.50 |
#6 |
Basically, I removed the original seats and frames and set them on the floor to measure the seat height(place where your a$$ rests). I then removed the seats from the frames and layed the Explorer seats on top of the frames and measured them. Since the bolt pattern on the Explorer seat was different than the YJ pattern, and the seat height is substantially higher, I cut the top off the frame and welded flatbar across it in a position to line up with the mounting holes on the Explorer seats. Then I drilled the holes and bolted them up. I re-installed the frames with the seats attached back into the original position. I tapped a lead from the battery, fused it and voila, power seats!!. They are a bit wider than the original seats, but much more comfortable. I also squeezed the center console from the Explorer in between the seats and it is much more user friendly and convinient than the original YJ console.
Phil |
#7 | |
#8 | |
I'll take some good pics tomorrow. I'm away right now. Thanks, Phil |
#9 | |
Thanx, follow up with a PM instead of here. -Rusty ![]()
#10 |
don't fear the Jeeper
If this might become a sticky, then might as well add fac. replacement seats to the mix, cause there is good and bad.
I have the old Steelhorse Super seat recliner. Bought out by 4WP's and now under the name Pro-comp. Direct bolt in. Not the greatest seat for a couple bills, but waaaay better than stock YJ seats! I also tried the cheaper bottom of the line fac. seat replacements prior to these. DO NOT get these seats! Although they say fac. raplacement for a YJ, they are twice as high/thick on the bottom seat area and your legs cannot fit between the seat and the steering wheel... even w/tilt. They also don't recline/adjust. Don't waste your time or money. I have no first hand experiance with Bestop, but they are very similar and a little more $$$. Some of the earlier YJ models require extra brackets for install according to their adds. WRM ![]()
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <>< |
#11 |
BUILT. NOT BOUGHT.
2003-2006 Rubicon Seats w/ YJ Risers and NO sliders
![]() http://www.jeepforum.com/forum/f12/03-tj-seat-swap-questions-suggestions-425843/
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#12 | |
I may add this when I am done but for now this thread will stick to non aftermarket swaps. The point is to get a list of the easy, cheap swaps from existing veichles. -Rusty ![]()
#13 |
I used 60/40 split bench seats out of a 94 Ford Ranger. Drilled 2 holes, and BAM! they're on. They do not adjust and you have to ditch the center console, but it has a fold down armrest with a storage are in it. I'll snap some shots of it later. Its a little tall, but it doesn't bother me. I'm 5'11" 220 and don't have any issues with it.
1989 Jeep Wrangler YJ- PARTING OUT- http://www.jeepforum.com/forum/f149/89-yj-part-out-862198/ |
#14 | |
Would definatly like to see some pics. Pics of the mounts as well.
#15 |
aka Jamesx2
2000 Cavalier seats but they werent a direct bolt on.
I had to drill new holes to get the jeep sliders to fit [IMG] [/IMG]
My 2.5 to 4.3 swap thread http://www.jeepforum.com/forum/f12/4-3-swap-has-finally-begun-1237704/ If your going to talk about me talk to me |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
