Replacement Hardtop Rear Window - JeepForum.com
post #1 of 5 Old 05-26-2012, 10:33 AM Thread Starter
bad_andy24
'94 YJ SteelHorse Targa Top(section over the front seats comes off seperate) Spice Color(shouldn't matter cause there's only some black trim on the bottom of the window). I need the whole rear window set-up: glass, attached trim, hinges, and piston openers. I busted the window screwing around in college with some buddies on a camping trip tryin to climb a hill with no winch. Needless to say a tree won that battle. Anyway, the last time I contacted Steel Horse(I think they're outta biz now) they had outsourced the parts to that top to some company in Compton,CA that wanted $800+ for just the window. Hoping to find a junkyard option or some great fab ideas from the forum. Any ideas would be greatly appreciated.
bad_andy24 is offline
post #2 of 5 Old 05-26-2012, 10:41 AM
jeepyj13
I found a jeep junkyard store on ebay. Bought my rear hardtop glass from them with wiper, matching factory tint, hinges for like 400 bucks and thats shipping included.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #3 of 5 Old 05-26-2012, 07:37 PM
SeanB95YJ
IMHO, don't deal with glass if you don't have to.
Measure the width of the glass (or where the glass should be) at the widest point, then the height at the highest point.
Then go to a local glass shop with those dimensions and get yourself a rectangular piece of 1/4" polycarbonate... Lexan MR-10 or Makrolon AR (depending on who they're a dealer for)
Take that rectangular piece home and cut it to your shape with a jig saw with a medium-fine tooth blade (and go slow). Polycarbonate can be cut, drilled, edges sanded, etc with no need for special tools. There should be a peel-coat on both sides... leave that on until JUST before you're ready to install, or if you're good with the razor knife, leave it on until AFTER you're done installing.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 5 Old 05-27-2012, 01:02 PM Thread Starter
bad_andy24
Thanks SeanB95YJ,
Couple questions:
1. Will the polycarbonate look like glass from a distance?
2. Can you apply regular window tint to the poly carb? (The side windows are lightly tinted and I may try to match it as close as possible so the back doesn't look funny)
Thanks,
Andy
post #5 of 5 Old 05-27-2012, 07:47 PM
Old4X
1990 CJ7
It is available tinted. one source:
http://www.eplastics.com/Plastic/Tra...arbonate_Sheet
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
