Replaced water pump now belt won't align HELP - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Replaced water pump now belt won't align HELP
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-06-2012, 12:28 AM   #1
Mwcaseface
I recently bought an 89 yj wrangler with a 4 cyl. I replaced the water pump today but when I went to put the serpentine belt back on I couldn't get the belt to line up. The belt guide that bolts to the new water pump doesn't go deep enough to allow the belt to have a place to glide on, about a belt width to shallow. I started looking close and this isn't the factory motor. It is a jeep 4 cyl. But I have no clue what year. Where can I get this part and what do I need to ask for? What kind of $$ am I looking at? Please help!!!
Mwcaseface is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 06:01 AM   #2
nembudonna
You have a serpintine belt on an 89?
nembudonna is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 06:50 AM   #3
HARLEYX2
1987 YJ Wrangler
Wrong water pump probably
HARLEYX2 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 07:14 AM   #4
Que89YJ
You should have a V belt on an 89. If not the engine is not the original engine and you will need to do some leg work. The casting number on the block will tell you where it came from to get the correct part. I would take the old water pump with you to the parts store and try and match it up. It sounds like someone upgraded. Do you have a mutiport(multiple) fuel intectors on it or throttle body injector (one injector). A pic is worth a thousand words.
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 09:23 AM   #5
Siva283
Sounds like you have an engine from a 91 - 95 maybe even newer.
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 10:26 AM   #6
nembudonna
If you got a pump for an 89 you got the wrong pump.
Unread 01-06-2012, 10:44 AM   #7
Mwcaseface
Ok the stamp on the block is 53008403. Where can I reference this?
Unread 01-06-2012, 11:00 AM   #8
Mwcaseface
53008403 is what the stamp on the passenger side high in the block
Unread 01-06-2012, 11:17 AM   #9
Que89YJ
http://www.jeepforum.com/forum/f12/e...number-748501/
Its out of a 95
Unread 01-06-2012, 01:06 PM   #10
SDGBASSE
The year of the engine is not really important in this case, if you have a serpentine belt setup you need a water pump that matches the application, they don't spin the same way as the v-belt ones. Bring it back to the store and ask for a "serpentine" one and make sure it's right ( open the box).
Read this for more info: http://www.jeepforum.com/forum/f12/w...torial-893428/
[QUOTE=ZeroGravity;10681914]I didn't click the link because it says "power probe" in the url.[/QUOTE]
SDGBASSE is offline   Reply With Quote Quick reply to this message
Unread 01-06-2012, 01:12 PM   #11
Que89YJ
Yep, thats why I told him to take the old one down and make sure to match it up. Make sure it's the correct rotation too.
Unread 01-06-2012, 01:39 PM   #12
nembudonna
Take the old pump and make sure they're kissin cousions. Don't just do a fast once over. Look long and hard.
Unread 01-06-2012, 02:20 PM   #13
SDGBASSE
Yeah sorry wasn't trying to take anything off ya, just wanted to add a bit more, cheers!
Unread 01-06-2012, 03:37 PM   #14
Mwcaseface
Thanks everyone! I ran back down and checked the pump for a 95 and that was the right one and now I am all up and running. Thanks again !!!!
Unread 01-06-2012, 05:30 PM   #15
Que89YJ
SDGBASE no props for me. I am always glad to see you chime in! Always add more when you can! Every day I am here I learn something from someone posting up. I am never upset about someone being constructive and...even correcting me when I am wr..wrrrr....wrrrrro; Not right!
serpentine belt , water pump
