Replaced rear Axel with a LOCKER - JeepForum.com
post #1 of 27 Old 04-05-2011, 02:06 PM Thread Starter
Enriquegg34
Hi, Im new to this...
I have a 1995 YJ Wrangler, and my kid has a 1989 Jeep Wrangler Sahara 4.0.
We replaced the rear axle on the Sahara for a locker, only because it was ready and available plus real cheap. The original was in real poor shape and slipped alot we rebuilt it but the gears do not match 100% so its weak - loose.
The locker is stiff as heck, is there an additional stabilizing arm that needs to be installed? this thing kicks tons as if it were totally loose.
if so, picture anyone? is it an after market thing? or just need to weld some additional support?
Your help is greatly appreciated.
Enriquegg34
Enriquegg34 is offline
post #2 of 27 Old 04-05-2011, 02:21 PM
yellow2kgt
It sounds like you just installed an auto locker in the rear in place of the spider gears. Is that correct? If so, there may be some handling issues as the locker engages/disengages when getting on and off of the gas. This is not uncommon for a rear auto locker in a lightweight Jeep.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #3 of 27 Old 04-05-2011, 02:42 PM Thread Starter
Enriquegg34
Fix
So no real fix?
There has to be some sort of stabilizing arm or shock...
Anyone know?
Enrique
post #4 of 27 Old 04-05-2011, 03:39 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Say whaaaaaaaaat...
Any pictures / part names of what you installed?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #5 of 27 Old 04-05-2011, 07:31 PM
imstillatwork
Hi, and welcome.
We have a language barrier, or a terminology barrier. I can't quite figure out what you mean.
Did you just take out 4 small gears, or the big ring and pinion gears or everything?
What was slipping, the factory lsd? what gears don't match?
So is it stiff, or is it loose? what part is stiff, what part is loose?
A locker goes inside the differential housing and has no way of being reinforced or supported, so I think we are talking about something other than a locker
Don't give up, put some pictures of what you are talking about if you can
Enriquegg34
imstillatwork is offline
post #6 of 27 Old 04-05-2011, 07:59 PM
notmyj
We need pics and a clarification of what you did and what your talking about. We are more than willing to help but there is a lot of confusion in what you wrote.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #7 of 27 Old 04-06-2011, 07:04 AM Thread Starter
Enriquegg34
Nope, cant upload yet..... I took the entire axle with differential off the jeep, replaced it with another axle that has a locker-differential. that simple, only that now due to it being a locker it rocks stiff back and forth when you let go of the gas in gear.
Is there an additional stabilizing arm or shock that keeps it from rocking back and forth?
post #8 of 27 Old 04-06-2011, 08:11 AM
Doch80
I don't have any personal experience with auto lockers in the back, but from what I understand, the jeep is too light and has too short of a wheel base to cover up the loading and unloading of the locker in the rear when it disengages. That's why, from what I understand, many people go with manual lockers in the rear so they don't have to deal with what you are describing as, again from what I understand, you have to change your driving style on the street to compensate for the crazy behavior of the rear locker.
Also, I've never heard of or read anything that would alleviate the action with a shock or stabilizer arm. The axle itself shouldn't be moving any other than from the movement of the springs. In my mind, all the action you are describing is coming from the differential which in turn comes out through the wheels.
Just my thoughts...
Doch80 is offline
post #9 of 27 Old 04-06-2011, 08:30 AM
muddy93
1987 FSJ Wagoneer
Under what driving conditions are you noticing the "rocks stiff back and forth"?
Is it happening wile cornering? If so, are you on the the gass wile taking corners?
If this is happening wile cornering, the only thing you can do is change your driving style. When you power through a corner, it can cause the locker to lock. when this happens, you will usually get some under steer. Basically, when the locker locks, the rear axle tries to push the jeep straight, rather than let it turn. The only way to eliminate this is to coast through corners to keep the dif from locking.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #10 of 27 Old 04-06-2011, 02:03 PM Thread Starter
Enriquegg34
Lets say I am cursing down the street, if i take my foot off the gas and the jeep is still in gear it will rock front and back as if there were a lost of tension between the diff and the transmission.
Hmmm.. frustrated....
Enrique
post #11 of 27 Old 04-06-2011, 02:11 PM
muddy93
1987 FSJ Wagoneer
With it parked on a level surface, set the parking brake, and put the trans in neutral. crawl under it and see how much (if any) you can rotate the drive shaft.
Did you open up the "new to you" axle and check it out? It could be that the ring and pinion are worn a bit, or were not set up correctly, and you have excessive backlash.
Also, jsut a thought, did you check the rear brakes before putting the axle in? If the rear brakes are hanging up, they may be dragging, which would cause the jeep to abruptly slow down as soon as you let off the gas.
muddy93 is offline
post #12 of 27 Old 04-06-2011, 02:18 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
When I accelerate or let off the gas quickly my locker will toss me around a bit. It's a lock-rite lunch box style in the 8.8 rear. That is normal with an auto locker. all that is, is the rear wheels trying to spin at the same time and it will feel like it is pushing you around.
You are saying that you have a different gear ratio in the front axle than in the back axle... correct?
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #13 of 27 Old 04-06-2011, 02:45 PM Thread Starter
Enriquegg34
I have done this actually at a shop I lifted the jeep and drove it while in the air, back lash is what it does...
yes opened her up and made sure everything looked good.
yes, new brakes and lines
same gear ratio, just that theres nothing absorbing the tightness of the rear
post #14 of 27 Old 04-06-2011, 06:40 PM
tonylax48
maybe he is getting axle wrap?
1990 YJ soon to be 4.7L, auto, d30 4.11 w/ spartan locker, ford 8.8 4.11 open, sye, 4in RC 2in BL
tonylax48 is offline
post #15 of 27 Old 04-06-2011, 06:41 PM
rjbruzan
The rocking back and forth is normal in a short wheel base Jeep. If it is annoying now it will only get worse. If you dont like it and I dont blame you, you will need to remove the locker and put in some stock spider gears to get a normal driving Jeep.
Ron
rjbruzan is offline
axle , differential , locker , rear , sahara
d30 axel shaft removal with detroit locker??? bjbrowder YJ Wrangler Technical Forum 8 12-02-2009 12:50 PM
rear axel brownskill JK Wrangler Technical Forum 11 11-09-2009 09:52 AM
How can I ID what rear Axel I have? MSearider TJ Wrangler Technical Forum 11 12-08-2008 06:41 PM
Rear Axel, Help!!!!!! Vito5800 YJ Wrangler Technical Forum 5 01-28-2007 07:18 AM
axel and locker question SamsonXD YJ Wrangler Technical Forum 6 11-21-2006 09:04 PM
