replaced pinion seal - JeepForum.com
post #1 of 13 Old 08-29-2013, 08:44 PM Thread Starter
kjg26
kjg26's Avatar
I replaced my pinion seal on my Dana 30 with 4.10s using the mark the differentual, mark the yoke, market the nut method. Ive got a Aussie locker in the Dana 30 so I know my front drove shaft is spinning. Currently I have the Dana 35 with 3.07s installed still. Waiting for some free time for the 8.8 install.
What I'm trying to figure out is...how can I verify that I got the nut back in the correct place? Would driving around in two wheel drive tell me anything? Since the driveshaft IS spinning due to the locker? Or is my only way or telling to wait until I put the rear axle in and drive in four wheel? Or pull and use the diff gear paint method?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 13 Old 08-29-2013, 08:54 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
If your marked everything and put the nut back on in the same place I'm sure it's good. Did you do anything to keep the nut from coming loose? That's as important as getting it back on.
-John-
johnboy68 is offline
post #3 of 13 Old 08-29-2013, 09:04 PM Thread Starter
kjg26
kjg26's Avatar
Blue lock tite. Any aditional input?
kjg26 is offline
post #4 of 13 Old 08-29-2013, 09:17 PM Thread Starter
kjg26
kjg26's Avatar
Would I be able to hear or feel anything while driving in 2 wheel with the Aussie in the front?
kjg26 is offline
post #5 of 13 Old 08-29-2013, 09:52 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Only if your shaft isn't balanced.
Luck Favours The Prepared
Anticanman is offline
post #6 of 13 Old 08-29-2013, 09:58 PM Thread Starter
kjg26
kjg26's Avatar
That would be the same as before I changed the pinion seal though right?
kjg26 is offline
post #7 of 13 Old 08-29-2013, 10:00 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
One would hope. If it chatters and locks up then you've got a problem. Just scribe the nut and check t every once in a while to see if it moves. If you've got a leak, that's even easier to see.
post #8 of 13 Old 08-29-2013, 10:35 PM
95YamJam
Not saying yours is wrong but.... On mine I used the rotational torque method as a first and a mark the nut second. If I had gone by the mark the nut method it would have not been within spec. You will find out pretty fast if she is not right.
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline
post #9 of 13 Old 08-29-2013, 11:06 PM Thread Starter
kjg26
kjg26's Avatar
Lol. Guess its too late now. Time will tell. Hopefully the 8.8 will be in in the near future. Thanks all!
kjg26 is offline
post #10 of 13 Old 08-30-2013, 01:23 AM
fratis
fratis's Avatar
What you are trying to circumvent is pulling the carrier and using an inch/lb torque wrench and setting the pinion preload properly. Many people get away with all manner of tightening it back down and never seem to report back that they had trouble. If they had trouble there would be a percentage that wouldn't post anyways. My first attempt i did it wrong and ended up with a loose pinion. Didn't cause too much trouble and there were no audible/visual signs other then when i grabbed the shaft and tugged on it. If it were a rear it would be a different story.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #11 of 13 Old 08-30-2013, 05:40 AM
bogleparsons
As long as you put the same shims back in the pinion just crank the nut to the corrcet torque value.
YJ Dana 30 doesn't have a crush sleeve right? well mine didn't So you cant really go to far if you torque it to spec.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #12 of 13 Old 08-30-2013, 07:00 AM
1998zj
Yup, no crush sleeve on the 30. If it tight, you should be ok. You just don't want any play in the bearings or you will destroy it.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #13 of 13 Old 08-30-2013, 08:15 AM Thread Starter
kjg26
kjg26's Avatar
Ok. Torque on this puppy is 200 ft/lb?
kjg26 is offline
