Replaced output shaft seal. ?'s - JeepForum.com
post #1 of 6 Old 02-20-2010, 08:13 PM Thread Starter
Cards89YJ
I replaced my tc rear output shaft seal, along with both ujoints on my rear drive shaft.
I tried to clean up where the yoke had been slinging oil all over the undercarriage of the jeep, but it was a mess. I drove the Jeep and am not really sure if the leak has stopped or not. I have one concern though. The picture is not great, but see how the rubber boot, doesn't sit quite right on the yoke shaft in one spot. Should I be concerned? I can't remember if the old one did this or not.
I do have a lift on my jeep, but I have attached pics of both ujoints on the rear shaft and you will see the angle is not bad.
If I need to put fluid back in my TC, what do I use? What is the easiest way to put it in?
IMAG0036 on Flickr - Photo Sharing!
seal
IMAG0038 on Flickr - Photo Sharing!
front ujoint on rear shaft
IMAG0039 on Flickr - Photo Sharing!
rear ujoint on rear shaft
Sorry for the pics, but this is the best I could do in the dark.
Oh yes, I think I also have a transfer case drop. There are 1" spacers between my frame and the transmission/tc skid plate.
Cards89YJ is offline
post #2 of 6 Old 02-20-2010, 08:19 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Can you get a better pic of that seal??? It looks like it is not seated all the way.
Did you do this swap in the rig out pull the tail cone off??
You should have lost fluid if you pulled the tail cone off. You need to pull the two 30 MM bolts off the back of the tcase and do a fluid change. Put in ATF. There is a write up in the FAQ sticky under the trans area of the write up list.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 6 Old 02-20-2010, 08:22 PM Thread Starter
Cards89YJ
I did pull the tail cone off. I had my jeep front end pointed down my driveway, so I really didn't lose very much fluid at all. Really, I only lost was was already sitting the the tail cone. I will see if I can get better lighting and a better picture. The metal part of the seal is tapped flush all the way around the tail cone. What else would I need to do?
post #4 of 6 Old 02-20-2010, 08:28 PM
rustywrangler
If it is flush then I don't know. The two that I have done were flush and squared off, not "bent" like that.
post #5 of 6 Old 02-20-2010, 08:40 PM Thread Starter
Cards89YJ
I have uploaded two more pics. Still not great, but a little better. It is really just the rubber boot part. It is only kicked out on this one spot.
IMAG0041 on Flickr - Photo Sharing!
IMAG0040 on Flickr - Photo Sharing!
post #6 of 6 Old 02-20-2010, 08:42 PM
rustywrangler
I would say you are ok. I would still do a fluid change though.
My XJ lost over a quart with a rear seal leak.
Replaced rear output seal? What did you use? Imped TJ Wrangler Technical Forum 1 01-25-2010 08:14 PM
Just replaced rear output seal. Have leaks again! (Black_Jeep) TJ Wrangler Technical Forum 5 10-28-2009 11:57 AM
New seal for output shaft on 231? blacktjsport TJ Wrangler Technical Forum 4 11-30-2006 03:37 PM
Rear output shaft seal peebut YJ Wrangler Technical Forum 4 09-13-2005 09:38 PM
Output shaft oil seal Slim YJ Wrangler Technical Forum 5 03-26-2003 12:38 PM
