Replaced Heating Core, Now Jeep Won't Start... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Replaced Heating Core, Now Jeep Won't Start...
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 03-18-2015, 10:47 AM   #1
AdrianK
Hey guys,
I just replaced the heater core on my jeep yesterday, everything went swimmingly, but now for some unknown reason the jeep won't start. I turn the ignition and the starter doesn't even click now.
The jeep had absolutely no problems running pre-Heater Core exchange, and I didn't touch anything that wasn't directly related to what I was working on. I followed This guide from the website to the letter.
I'm thinking I knocked something loose when I was mounting it back under the dash, but I can't see anything unpluged when I get under there to look around (I really think this is the problem, as the guages on the dash don't so any more than light up now). So then I thought maybe I knocked something loose in the engine compartment, but I don't see anything loose in there either.
The battery is 95% charged, so that isn't the problem either, and it powers the lights when I turn the key into that position.
Any ideas on what could be the problem?
AdrianK is offline   Reply With Quote Quick reply to this message
Unread 03-18-2015, 10:49 AM   #2
AdrianK
Forgot to mention, its a 1994 manual 4cyl, if that matters much.
Unread 03-18-2015, 10:50 AM   #3
mike134
Does the Check Engine Light (CEL) come on when you turn the key to ON (not start)?
do any indicator lights come on when you turn the key to ON?
mike134 is offline   Reply With Quote Quick reply to this message
Unread 03-18-2015, 11:15 AM   #4
boduke5051
From the sounds of it, I would double or triple check all of the wiring to the starter. Possibly something came loose from the positive battery terminal when you had the battery and the tray out.
Also double check all of the ground connections from the battery.
If you can't be good, be good at it! >:-D
http://www.jeepforum.com/forum/f286/hound-2833082/
boduke5051 is online now   Reply With Quote Quick reply to this message
Unread 03-18-2015, 12:10 PM   #5
AdrianK
No indicator lights come on at all when the key is turned to ON. I am currently checking the wires to the starter, so far nothing looks amiss.
Unread 03-18-2015, 12:44 PM   #6
mike134
Will your radio power up with the key in the ON position?
Unread 03-18-2015, 12:51 PM   #7
AdrianK
Nope. No power to anything inside the car.
Unread 03-18-2015, 12:56 PM   #8
Drednot
Drednot's Avatar
Pics of the battery firewall area?
Is that gang of ground wires to the firewall hooked up/ clean and tight?
91 YJ Sahara, 4.0L, AX-15/NP231, D30/D35
12 Cherokee 4x4,3.7L,
"Non Vi Sed, Arte"
Drednot is offline   Reply With Quote Quick reply to this message
Unread 03-18-2015, 01:38 PM   #9
AdrianK
Heres what I'm working with. Not so clean, but everything is like how it was when I bought the car a few months ago. Took the battery out to get a picture of behind the battery, just incase.
My father said maybe I should open the fusebox and check inside of it to see if anything got loose in there when I had to move it to get to the heater core. Sound like a good idea? I know less than nothing about electrical work, so I don't wanna jump into that and mess something up if it won't even help me.
I'm going to have to head out to work in the next few minutes, so this is probably as far as I'm getting on this today. I really, really appreciate all the help guys!
Unread 03-18-2015, 02:03 PM   #10
bharris68
Check the ground from the battery to the motor and the condition of the ground in general. It sounds like it's fractured inside the insulation.
bharris68 is offline   Reply With Quote Quick reply to this message
Unread 03-18-2015, 02:06 PM   #11
JeepinJeremy
Did you scrape the paint out of those fancy painted battery terminals?
JeepinJeremy is online now   Reply With Quote Quick reply to this message
Unread 03-18-2015, 02:15 PM   #12
AdrianK
The battery terminals work. no paint on the inside.
Will do! I'll report back with how that looks when I get a chance.
Unread 03-18-2015, 02:29 PM   #13
bergovoy
check the fuse panel FIRST.. everytime..
there is a main fuse there and a couple others that may have been blown..
also, there is a large connector between the fuse box and the firewall, that connects the wiring between the inside and outside...
check that connector..
also, there is another connector near above the pedals that connects the steering column to the rest of the system... it sounds like you arent getting any 'signal's from the ignition switch to the 'anything else' really
good luck
help me out of a bad loan to a bad friend. You don't have to give a lot. $1. www.gofundme.com/ngext4
bergovoy is offline   Reply With Quote Quick reply to this message
Unread 03-18-2015, 04:20 PM   #14
TSEJEEPERS
Yep check the fuses first!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Unread 03-19-2015, 08:46 AM   #15
AdrianK
Oh I think I may have been unclear; I checked all of the fuses, they work fine. I meant the inside of the fusebox, like under the fuses. It looks like it comes off, so I imagine it could be in there somewhere?
electrical issue , heater core , ignition trouble , starter issue
