Replaced gas tank..... - JeepForum.com
post #1 of 10 Old 05-04-2011, 06:45 PM Thread Starter
hump0311
I replaced my gas tank today on my 89 yj 2.5. Does anyone know what the purpose of the two "necks" that stick out of the upper right side of the tank?( opposite of the vent and filler connectors) When I removed the old tank there were two rubber hoses that connected to a "t" and the "t" connected to a metal tube that had been capped off. Also there is a hose coming from the fuel rail to the tank that is not connected to anything. My thoughts are, that the capped off metal tube is somehow connected to the loose ?fuel? line that is not connected to anything. Does anyone have a clue as to what I am trying to explain? Any and all help would be appreciated.
hump0311 is offline
post #2 of 10 Old 05-04-2011, 07:00 PM
Mark455SD
1961 CJ5
Are you talking about the two roll over valves?
Mark455SD is offline
post #3 of 10 Old 05-04-2011, 07:15 PM Thread Starter
hump0311
not sure
not sure. it is on the right side as you are looking at the rear of the vehicle. there are two connections.
hump0311 is offline
post #4 of 10 Old 05-04-2011, 07:31 PM
gunshw301
I think pics will help us help you.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
My 1994 yj build page
gunshw301 is offline
post #5 of 10 Old 05-04-2011, 07:37 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
I think this is what you are missing:
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #6 of 10 Old 05-04-2011, 08:00 PM Thread Starter
hump0311
that is it....
that is it, do you know it's function? i should have taken pics before i reinstalled the tank.... i have been looking for some pics of others but to no avail. thanks laybackman and everyone else who responded so far.
hump0311 is offline
post #7 of 10 Old 05-04-2011, 08:01 PM Thread Starter
hump0311
laybackman can you lead me to the source of that diagram?
hump0311 is offline
post #8 of 10 Old 05-05-2011, 06:24 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
It is a page out of a factory parts manual. I came across it online sometime ago. I did a Google search for Jeep YJ parts manual, and came across it.
post #9 of 10 Old 05-05-2011, 06:38 AM Thread Starter
hump0311
ok thanks everyone
hump0311 is offline
post #10 of 10 Old 05-05-2011, 08:10 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
The valve is part of a closed fuel vapor recovery system. If the fuel expands it wants to expel excess gas vapors from the tank. Before it just vented to the atmosphere. Now it is stored in the charcoal canister and burned off at some later time.
fuel , gas tank hose , vent hose
Tank replaced and now noticed fuel lines hanging over the exhaust NotmyJK JK Wrangler Technical Forum 2 04-22-2011 08:11 AM
Replaced blower, replaced resistor... still fan doesn't work Levin2000 TJ Wrangler Technical Forum 1 12-19-2009 03:47 PM
gas tank needs replaced JAnurse08 YJ Wrangler Technical Forum 3 08-05-2009 01:58 PM
replaced fule tank sending unit gasket and jeep won't start llunsford YJ Wrangler Technical Forum 11 03-10-2009 02:28 PM
92 gas tank leak / problem after being replaced...Help? Suggestions? jafo67 YJ Wrangler Technical Forum 5 09-18-2008 02:02 AM
