Replaced clutch, slave, master, bearing, etc... drove nice only for about an hour? - Page 2 - JeepForum.com
post #16 of 18 Old 01-09-2012, 01:22 PM
tommbstone
Ok bro here is the fat truth.
DON'T buy master or slave from kragen O'rileys what ever. Please I've done this too and its nothing but hell
Get a napa on both master and slave.
Your O'riley clutch and throw out bearing are fine... but don't buy these types of parts there. china junk
You will thank me later.
tommbstone is offline
post #17 of 18 Old 01-09-2012, 05:02 PM
dancytron
You can switch it over to an external slave cylinder, like the later (94??) model. Then at least you don't have to take the transmission out to change it.
dancytron is offline
post #18 of 18 Old 01-20-2012, 01:40 PM Thread Starter
91YJOWNER
It was the master, which made the fix easy. Part was warranted, but if it happens again I will buy Napa parts. Next issue with slave will get converted as mentioned. Thanks for the input.
91YJOWNER is offline
clutch problem
replaced the slave and clutch master cylinder and now wont crank hvacguy TJ Wrangler Technical Forum 16 09-19-2009 05:47 PM
master and slave cylinder replaced now wat? tjwrangler97 TJ Wrangler Technical Forum 6 12-27-2007 08:45 AM
Replaced Slave and Master still shifting hard (HELP!) jbanks25 YJ Wrangler Technical Forum 2 07-15-2006 05:41 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
Replaced clutch master/slave cyl, still having issues. Now what? mr_man YJ Wrangler Technical Forum 1 07-02-2004 03:10 PM
