Replace front U joints. - JeepForum.com
post #1 of 3 Old 05-13-2013, 07:55 PM Thread Starter
animal0307
I apologize if this has been asked before but I couldn't find it after a quick 10 minute search.
How do I replace the U Joints in the front axle by the wheels? I have a clicking coming the front of my jeep when I turn and the drivers side has some play in it. Is it a hard fix? Anything else I should look at while I'm at it? Should I just go through and do all of the U joints? Part numbers or brands I should look for?
animal0307 is offline
post #2 of 3 Old 05-13-2013, 08:39 PM
SeanB95YJ
need to pull the wheels, brake hardware, then unbolt and remove the hub unit bearing. if it hasn't been done in a long time, now would be a good time to also replace those unit bearings since you've got to remove them anyway.
start WELL in advance (like a week or more) with a few cans of PB Blaster and spray all the bearing bolts as well as the axle u-joints to make disassembly a bit easier when you go to do it.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 3 Old 05-13-2013, 11:24 PM
TSEJEEPERS
http://www.jeepforum.com/forum/f12/a...a-30-a-360209/
Two second search in the FAQ
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
