Removing windshield - JeepForum.com
post #1 of 11 Old 03-06-2013, 10:41 AM Thread Starter
jural
Removing windshield
I have begun the prep process for painting. I wanted to remove the windshield from the jeep to sandblast and paint separately. When I tried to remove the bolts with the star bit, most of them stripped out. Is there an easier way to do this? Will I have to drill them out now? Thanks for the advice.
Rob
jural is offline
post #2 of 11 Old 03-06-2013, 10:59 AM
SeanB95YJ
once they're stripped (too easy to do) you've only got a few options
1- weld a nut to the head so you can use a standard socket on it (probably best method to try if you have access to a welder)
2- with a cutoff wheel, cut a slot in the head so you can try and use a flat screwdriver (but if it's that stuck, that slot will probably strip out too... then back to #1)
3- drill it out as large as you can and use an ez-out
good luck
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 11 Old 03-06-2013, 11:15 AM
bogleparsons
I drilled the head off the bolt and once I removed the spreader bar could grab what was left with Vise Grips.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #4 of 11 Old 03-06-2013, 11:52 AM Thread Starter
jural
I have already done some primering around it so I hate to weld. But I may have to. That sounds like the most dependable solution. I will definitely go with some stainless bolts when I put it back together.
jural is offline
post #5 of 11 Old 03-06-2013, 12:01 PM
insaneinline
I did the same thing as bogleparsons , if put stainless make sure you use anti seize on them before putting the bolts back in
insaneinline is offline
post #6 of 11 Old 03-06-2013, 12:07 PM
befumo
Impact hammer for the bolts, has worked for me. If i don't use it they just strip.. or at least that's the way it is with the windshield frame.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #7 of 11 Old 03-06-2013, 12:10 PM
CrawlingForward
Wait....which bolts on the windshield?
Are you removing the entire hinge, or just unbolting the top bolts? If you're taking off the bottom half of the hinge, just drill the rubber-ducker out. There are nuts on the other side that just spin. If you do a search for "YJ mirror relocation bracket install" you'll see what I'm referring to. You pretty much have to take the dash off to get to them.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #8 of 11 Old 03-06-2013, 12:27 PM Thread Starter
jural
I wanted to completely remove the hinges from the frame. Was going to sandblast them and repaint to remove rust.
jural is offline
post #9 of 11 Old 03-06-2013, 12:32 PM
CrawlingForward
Yup, just drill them out, then.
Not worth struggling with the old ones. In the process of drilling them out, it should pop off the nut on the other side if it's not already broken loose.
When you reinstall, you just add a regular nut to the backside. (You can put a wrench on when you tighten or just tack weld/adhesive it to prevent needing to take off the dash next time you want to pull that bolt.)
EDIT: I'm only referring to the bottom section of hinge. I don't know about the backside of the upper bolts. Someone more knowledgeable will have to pipe in about that.
post #10 of 11 Old 05-30-2013, 10:54 AM
redbullrr
1987 YJ Wrangler
I dremmeled the heads off, and hit it with hammer and screw driver. This was a PITA
redbullrr is offline
post #11 of 11 Old 05-30-2013, 11:31 AM
Old4X
1990 CJ7
I try with an impact gun first. If the bit slips one time, I drill. No need wasting hours on these old bolts, just drill them out and move on.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
