Removing the transfer case with some problems - JeepForum.com
post #1 of 31 Old 12-14-2011, 11:08 AM Thread Starter
nightridder
hi im new to the form and im new to the jeep world but i had a struck of bad luck the other day. i was just taking off from four way stop and i hear a loud crack then grinding. i role to the side of the road and see trany fluid just flowing out from my transfer case. i though i had just cracked the extension housing because that all could see at the moment. so i got a toe home and took the rear drive shaft off then took the housing off and found out that it was also the outgoing shaft that broke and i mean it really broke. i have pictures of anyone wants to see and it helps me out.
my problem right now is that i cant removed the skid plate because the bolts are welded in to place. why that was done i have no idea. so my option now seems to be that i have to just take it out with out removing it......anyone got some advice before i start going at it?
nightridder is offline
post #2 of 31 Old 12-14-2011, 11:11 AM
scubamc
It is going to be almost impossible to remove the tcase without dropping the skid. Cut off the bolt heads then drill and retap.
scubamc is offline
post #3 of 31 Old 12-14-2011, 12:35 PM
jsawduste
2006 YJ Wrangler
Take it out from the top by removing the tub.
Cutting a hole ion the floor comes to mind also....................
jsawduste is offline
post #4 of 31 Old 12-14-2011, 12:37 PM Thread Starter
nightridder
what are you referring to when you say remove the top? is that something that you can do and then undo easily
post #5 of 31 Old 12-14-2011, 12:41 PM Thread Starter
nightridder
Uploaded with ImageShack.us
post #6 of 31 Old 12-14-2011, 12:42 PM Thread Starter
nightridder
post #7 of 31 Old 12-14-2011, 12:45 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
You can't remove the t-case with the skid in place.
1. cut the skid off
2. chop big strategic holes in your tub to access the t-case bolts.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #8 of 31 Old 12-14-2011, 12:50 PM
Ripper3494
ive done that, you need to drop the skid plate, ive done it with it up once and it was probably the worst experience ive ever had with my jeep. my skid was welded as well... what i did is drilled out the original bolt holes and welded new studs sticking straight down for the skid to bolt onto
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #9 of 31 Old 12-14-2011, 12:54 PM Thread Starter
nightridder
this seems to be getting more and more complicated. what would you all estimate is going to cost to fix this?
post #10 of 31 Old 12-14-2011, 12:57 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
A used t-case $70 bucks.
cutting the skid plate off = the cost of cut off wheels
fabbing up new skid plate mounts = 6 bolts and welding
Figuring out why it broke where it did is just as important as the fix. How much suspension lift do you have?
Poke is offline
post #11 of 31 Old 12-14-2011, 12:58 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
can you post picture of how the skid is welded to the bolts?
Poke is offline
post #12 of 31 Old 12-14-2011, 01:01 PM Thread Starter
nightridder
i dont have a lift on it. its all stock. and my bad but the bolts aren't welded it was the spacers that i was looking at and is welded. it has bolt with alen wrench heads and ive tried my hardest to get them to loosen with no success
post #13 of 31 Old 12-14-2011, 01:13 PM Thread Starter
nightridder
which would be better. to just get a used to new tcase or to replace the outgoing shaft
post #14 of 31 Old 12-14-2011, 01:15 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Something is strange here.
If it is all stock, it should not have any spacers. spacers typically come with lift kits to help with the drive line angles.
The are probably rusted in place. A few things...
1. spray them with PB blaster and let them sit.
2. if you have a torch you can heat the bolts up then try to remove them
3. it will take a lot of elbow grease to get them out.... think in terms of a 2-3 foot breaker bar.
4. don't be surprised if you break a few or they spin in place, we can guide you through fixing that
5. SUPPORT THE TRANNY WITH A JACK STAND BEFORE TRYING TO DROP THE SKID. The skid holds the t-case, tranny, and engine where it all is. you need to support the tranny just in front of the skid with a jack stand. I even recommend jacking the tranny up an inch, then putting a jack stand in. this takes any weight off the skid plate. you do not have much room to work with on the tranny, figure it out.
6. unbolt the 3 nuts sticking down through the skid plate first. before doing anything else
7. read all of these numbers before starting
Poke is offline
post #15 of 31 Old 12-14-2011, 01:17 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
in my opinion.... a used t-case would be easiest, quickest and least technical.
Poke is offline
removing transfer case to install tjluke TJ Wrangler Technical Forum 1 10-01-2011 12:43 PM
Removing Transfer case drop fixed Transmission Problems, Why? gsharum YJ Wrangler Technical Forum 3 01-23-2011 10:16 AM
Removing transfer case for SYE don2510 YJ Wrangler Technical Forum 18 02-16-2009 03:02 PM
Removing Dampner on Transfer Case TimBrown TJ Wrangler Technical Forum 6 01-09-2009 11:33 PM
removing transfer case joe's_yj YJ Wrangler Technical Forum 6 08-07-2007 10:14 PM
