Removing side carrier bearings - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Removing side carrier bearings
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!Genright at JeepHut
Unread 05-23-2007, 10:32 AM   #1
sequel
Working on getting tools and info to regear my D30. For all you that have regeared, how did you remove the side carrier bearings?
1992 Black YJ, 4L I6, 8.8 Rear
3.5" BDS, 5/8" MORE Shackles,
DT-3000s, 16x8 Bajas,
285/75R16 Dunlop Mud Rovers
sequel is offline   Reply With Quote
Unread 05-23-2007, 12:41 PM   #2
bogger jeep
i'm using a bearing puller. it slides in under the bearing ,then presses the carrier and lifts the bearing off.
bogger jeep is offline   Reply With Quote
Unread 05-23-2007, 03:14 PM   #3
93YJfalcon
I took mine to a local machine shop. They pulled them off, then I took 'em home and made set-up berrings out of them, set up my gears and took the diff back to have the new berrings pressed on. Way easy
ROCK OVER LONDON... ROCK ON CHICAGO!
http://dirtyfabworks.com/gallery.htm
93YJfalcon is offline   Reply With Quote
Unread 06-26-2007, 12:01 PM   #4
sequel
Do you have a picture or link to the type of puller you are using?
Unread 06-26-2007, 02:32 PM   #5
kloppk
Bearing Seperator....
kloppk is offline   Reply With Quote
Unread 06-26-2007, 03:08 PM   #6
sequel
may be a stupid question, but do you use the bearing separator as a wedge between the carrier and the bearing and tighten the separator down?
