Removing rear axels on a dana 35 with a locker - JeepForum.com
post #1 of 5 Old 02-02-2012, 11:10 AM Thread Starter
Stefans94
I have a 94 wrangler se i just got done replacing the front hub assemblies and u joints as well as the rear drive shaft u joints. i'm now moved to the back end and i need to replace the bearings but, i can't identify how to remove the axels. i have never dealt with a locker before do they have c clips? HELP!
Also call me a newbie or an idiot but, i cannot for the life of me find where to fill my trans at........
any thoughts thanks,
Stefan.
Stefans94 is offline
post #2 of 5 Old 02-02-2012, 11:32 AM
Louie4
Your D35 has c-clips that are probably tucked away in the locker. I know mine were a pain to get to but eventually it will come out. What kind of locker is back there anyway?
As far as changing the tranny fluid. Here's a good write-up from Mean Max in the FAQ sticky.
http://www.jeepforum.com/forum/f12/b...change-865520/
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #3 of 5 Old 02-02-2012, 11:35 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Stefan.
What kind of locker do you have?
I have removed the shift stick and filled my tranny from inside the jeep.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #4 of 5 Old 02-02-2012, 12:05 PM Thread Starter
Stefans94
this is the locker i'm not sure what it is i bought it with it in.
thanks for the help!
so i'll push the pinion through and the c clips with be behind that?
sorry im brand new to the whole rear dif.
post #5 of 5 Old 02-02-2012, 12:06 PM Thread Starter
Stefans94
i know it looks like the ring gear has been scrapping but, i believe it has been replaced and the locker has not there are no teeth missing and there were no metal shavings in the fluid.
locker , rear axle , removal , wheel bearing
Dana 44 rear locker advice Dorian772 TJ Wrangler Technical Forum 36 12-31-2011 08:36 PM
Dana 44 rear with OX locker. Bad idea? Treeshot TJ Wrangler Technical Forum 8 05-11-2009 08:04 AM
Removing rear locker, back to stock lillyrat YJ Wrangler Technical Forum 11 11-15-2008 05:48 PM
removing rear locker mean90yj YJ Wrangler Technical Forum 6 05-02-2007 04:14 PM
Thinking of removing the rear locker and installing a front locker Muddeprived TJ Wrangler Technical Forum 6 06-21-2005 03:14 PM
