removing hp dana 30 differential - Page 2 - JeepForum.com
post #16 of 21 Old 09-30-2013, 07:22 PM
Schaef81
Originally Posted by Brshpile
If you have a lunchbox style locker, it eliminates the use of a c-clip. I don't think that is your issue.
This is false. Given that my 8.8 has c-clips and needed to be reinstalled AFTER the locker was installed.
BDS - Spartan - AtoZ Fabrication - Borgeson HD - USA Standard - BFGoodrich
Schaef81 is offline
post #17 of 21 Old 09-30-2013, 07:25 PM
Apollo12227
There is no c clips in the d30. They're held in by the unit bearing
Some d30's absolutely had c-clips. Only on the passenger side to keep the center shaft in place during production process. This process was only done in some YJ d30's, the majority do not have c-clips.
Apollo12227 is offline
post #18 of 21 Old 09-30-2013, 08:38 PM
Brshpile
Schaef81,
That is absolutely correct in what I said. My D30 had a c-clip on the passenger side axel. When you install the lunch box it eliminates the use of it. No where in this entire conversation where we talking about an 8.8
Brshpile is offline
post #19 of 21 Old 09-30-2013, 09:03 PM
Schaef81
Schaef81, That is absolutely correct in what I said. My D30 had a c-clip on the passenger side axel. When you install the lunch box it eliminates the use of it. No where in this entire conversation where we talking about an 8.8
Fair enough
Schaef81 is offline
post #20 of 21 Old 09-30-2013, 09:38 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
100% correct!
Joe Dillard is offline
post #21 of 21 Old 10-01-2013, 05:44 PM
imstillatwork
And you do not NEED the c clip on the center axle regardless of a locker install or not. It was apparently a factory ease of assembly thing.
imstillatwork is offline
