removing hp dana 30 differential - JeepForum.com
post #1 of 21 Old 09-29-2013, 04:26 PM Thread Starter
bigorangeyj
I need some help. I'm trying to remove the differential in my 87 yj. I've removed the driver side axle and the passenger side outer shaft, but cant get the inner shaft out. I've read through different how to's, but cant figure it out. Apparently theres a c clip, but I can't find it. I even unbolted the ring gear from the carrier to give me some more looking room. It's the factory carrier with a lunchbox locker if that changes anything.
02BLKTJ-35" MTR/K's, savvy 4", 4.88's, Detroit True Trac 44 rear, Aussie HP 30 front, Big Stereo.
bigorangeyj is offline
post #2 of 21 Old 09-29-2013, 04:47 PM
alc60560
It should just pull right out. My 92 did not have a c-clip. Try to spin it when pulling
alc60560 is offline
post #3 of 21 Old 09-29-2013, 05:45 PM
YJames90
YJames90's Avatar
Spray brake clean around the bearings to loosen the suction of the grease. a pry bar helps too
My 2.5 to 4.3 swap thread
YJames90 is offline
post #4 of 21 Old 09-29-2013, 08:39 PM Thread Starter
bigorangeyj
Getting the carrier apart from the housing isn't the problem, it's getting the inner axle out of the carrier that's the problem. If it wasn't for the axle being stuck in, the carrier would just fall out. I've tried beating and prying the axle out, but no luck. It has about an inch of back and forth playand it feels like there's a c clip holding it, but I can't see where one is. Anyone have suggestions or pictures of where to look. I'm just trying to get the locker out of it.
post #5 of 21 Old 09-29-2013, 09:12 PM
jokerchief462
Mine slid right out no issues. Maybe the axle is twisted on its splines. I actually grabbed it through the CAD access cover and it just slid out.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #6 of 21 Old 09-29-2013, 09:28 PM
imstillatwork
I have heard of some D30 middle shaft having c clips in the carrier. remove the cross pin so you can push the axle inward far enough to see if there is one on there.
imstillatwork is offline
post #7 of 21 Old 09-29-2013, 09:33 PM
AmmitOsiris
AmmitOsiris's Avatar
I'm curious, why are you taking the locker out?
Sent from Peggy's office
AmmitOsiris is offline
post #8 of 21 Old 09-29-2013, 09:46 PM Thread Starter
bigorangeyj
putting it in another axle
post #9 of 21 Old 09-29-2013, 09:47 PM Thread Starter
bigorangeyj
I was gonna try that, but i cant get the cross pin out. Any pointers on that?
post #10 of 21 Old 09-29-2013, 10:16 PM
Apollo12227
The cross pin would definitely need to be removed to access any c-clip if one is present. I've been told that some of the factories installed c-clips to prevent the inner shaft from moving during assembly.
As for how to remove the cross pin, if it has 4.10 gears the ring has to be unbolted first and moved to the side as best you can with the carrier installed.
Apollo12227 is offline
post #11 of 21 Old 09-29-2013, 10:18 PM Thread Starter
bigorangeyj
3.07 gears. I'll go get the punch i need for it tomorrow and work on it.
post #12 of 21 Old 09-30-2013, 05:03 AM
mudsweatNgearz
1987 YJ Wrangler
On my 87 I just pushed axle all the way in and clip was visible and easily pulled right out but it had 3:07 gears.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #13 of 21 Old 09-30-2013, 08:20 AM
grandboost98
x2 but I have 4.10s
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #14 of 21 Old 09-30-2013, 09:24 AM
Brshpile
If you have a lunchbox style locker, it eliminates the use of a c-clip. I don't think that is your issue.
Brshpile is offline
post #15 of 21 Old 09-30-2013, 10:38 AM
AZdEvilYJ
There is no c clips in the d30. They're held in by the unit bearing
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
