Removing heater core. - JeepForum.com
post #1 of 11 Old 12-16-2008, 12:00 PM Thread Starter
heep1991
My heater core to a crap on me in TX but now im up here in Mass and its getting cold so I need to replace the heater core. I have looked into this a little and it looked like I had to remove the entire dash. Is this true or is it like a hour job to do? any suggestions or pictures would be great.
1991 YJ 2.5L - SOLD
2006 Jeep Commander 6cyl - SOLD
2007 Jeep Unlimited Rubicon 3.8L
heep1991 is offline
post #2 of 11 Old 12-16-2008, 12:02 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Read through thee threads... it's about a 2 hour job.
http://www.jeepforum.com/forum/f8/note-blazer-motor-upgrade-69254/
http://www.jeepforum.com/forum/f8/heater-upgrade-496120/
http://www.jeepforum.com/forum/f12/heater-upgrade-amazing-493878/
http://www.jeepforum.com/forum/f12/heats-kinda-blaa-489133/
- Ernie
Richmond88yj is offline
post #3 of 11 Old 12-16-2008, 12:12 PM Thread Starter
heep1991
http://www.jeepforum.com/forum/f12/heater-core-219329/
This one has pictures right on!
But I heard that alot of the times it could just be the hoses, I mean how would the heater core get a hole in the first place?? thats my questions.
Thanks Richmond
1991 YJ 2.5L - SOLD
heep1991 is offline
post #4 of 11 Old 12-16-2008, 12:32 PM
rrisher
1987 YJ Wrangler
Originally Posted by heep1991 View Post
http://www.jeepforum.com/forum/showthread.php?t=219329
Thanks Richmond
They corrode and rust out! Remember that coolant which is an acid is running through that thing all the time.
rrisher is offline
post #5 of 11 Old 12-16-2008, 04:17 PM
geekboy31
I just did that a few weeks ago. Not a bad job. Only problem for me was putting the screws back through the firewall. It was a PITA to get those lined up.!!! But now I have some HEAT!
geekboy31 is offline
post #6 of 11 Old 12-16-2008, 07:28 PM
PolakX
Not a bad job at all ... Did mine two weeks ago ... If you have a buddy to help out, it'll go alot easier!
92 YJ 2.5L 4" Skyjacker, 1" Body Lift, 33" BF M/T,Posi-Lock, Herc'd, ARB Safari Snorkel, Sanden On board Air, Electric Fan
Central NJ Offroading -
PolakX is offline
post #7 of 11 Old 12-16-2008, 07:35 PM
Brandon_YJ
1987 YJ Wrangler
Take the dash off nothing.
It's 4 nuts from off the firewall, a few clamps, an electrical plug, a snap clamp, and a handful of screws.
Shouldn't take long at all, it's a one man (2 beer) job.
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #8 of 11 Old 11-10-2013, 06:59 AM
nwjpown
Has anyone replaced the heater core on a 2006 jeep Wrangler [TJ] RHD or know where I can find info??
nwjpown is offline
post #9 of 11 Old 11-10-2013, 10:15 AM
trboxman
1987 YJ Wrangler
I'd look in the TJ forum if it was me...
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline
post #10 of 11 Old 11-10-2013, 01:24 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I did mine not too long ago, It takes about an hour and half. if you remove the passenger seat it gives you way more room to get in those awkward positions
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 11 Old 11-16-2013, 11:26 AM
87yjchris
1987 YJ Wrangler
My heater core went bad about two years ago. I fought the idea of replacing the heater core. I thought it would a PITA to replace.
On my YJ it's four nuts that hold the heater box / mixing box. The hard part for me was disconnection the cable from there brackets.
Other than that it came right. There is a good writeup here on how to. The other thing I found was to make sure the hoses fit and are tight.
87yjchris is offline
YJ Heater Core and Heater Motor Replacement?? Boston Mangler YJ Wrangler Technical Forum 11 11-29-2009 09:31 AM
Removing AC? Heater Core Issues FarrellX YJ Wrangler Technical Forum 1 08-21-2009 06:27 PM
Heater Core sky-raptor TJ Wrangler Technical Forum 1 02-11-2007 09:13 AM
heater core Genghis YJ Wrangler Technical Forum 3 10-25-2006 12:30 PM
Where to get new heater core? DCGayhart TJ Wrangler Technical Forum 3 10-23-2006 03:19 AM
