Removing front axle disconnect - JeepForum.com
post #1 of 7 Old 02-22-2014, 06:45 PM Thread Starter
94YJ4L
Anyone have experience "deleting" the front vacuum disconnect? I know I'll have to put in a full shaft on that side and manual hubs?
Just trying to see if it's worth the time and money to do it.
94YJ4L is offline
post #2 of 7 Old 02-22-2014, 07:23 PM
89yjislanderr
there are a plethora of threads on this subject. search bar
89yjislanderr is offline
post #3 of 7 Old 02-22-2014, 07:26 PM
89yjislanderr
post #4 of 7 Old 02-22-2014, 08:32 PM
linusb
Just modify your vacuum system to permanently lock the shafts.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #5 of 7 Old 02-23-2014, 09:10 AM
kjg26
kjg26's Avatar
i pulled my two piece shaft. Installed a new seal at the pumpkin end, and installed once piece cherokee or TJ shafts. You can block off the disco area with a plate or you can leave the cad acuator pump in place, just plug the vacuum ports. Problem solved. the hubs remain the same. Unless, of course, if you want to install selectable hubs. They are expensive though.
My whole conversion.
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #6 of 7 Old 02-23-2014, 09:19 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
No need for manual hubs.
You can delete the CAD in two ways: Permanently lock the fork over by sliding it on the shaft and re-installing the E-Clips. Or remove the CAD, remove the two piece axle setup, and install a TJ shaft in its place with new seals.
Personally, I just locked the CAD in place 5 years ago and have had no issues.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #7 of 7 Old 02-23-2014, 11:30 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Locking the cad fork over is the only temporary solution to a permanent problem that I can live with on the jeep.
Luck Favours The Prepared
Anticanman is offline
