Removing Fenders (plastic clips) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Removing Fenders (plastic clips)
All Bilstein shocks & struts - Lowest Prices Ever and TERAFLEX JK Speed bump kit AND limiting strap kit!! AT ROCRuffstuff Axle Simple Swap Kit!
Unread 03-19-2010, 08:03 PM   #1
91wrangleryj
Well I am continuing the tear down on my 91 yj. I am working with the tub removal FAQ at Tub Removal - JeepForum.com.
I got the grill removed ok.
However, when I tried to remove the driver side fender I ran into a snag.
I took out the 4 bolts attached to the tub and the 2 on the support brackets (yay for pb blaster! ). This left the fender ready to come off but it is held by 2 plastic tabs. I didn't want to break them off so I'll ask here how to remove them.
One's on the trim. Here is the outside look.
And here is the inside look (ugh so blurry!)
The other one is at the bottom of the fender near the support braces and is attaching some softer material. Sorry I don't know the proper term for the flimsy material it is holding up.
Any advice is appreciated.
91wrangleryj is offline   Reply With Quote Quick reply to this message
Unread 03-19-2010, 08:08 PM   #2
Opihi59
from here it gets rough
Opihi59's Avatar
You can pull those thru, the "fins" on the plastic will collapse when you pull on them, they come out fairly easily and most of the time can be reused. They do sell replacement ones at most parts stores, like in the "HELP" rack.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is online now   Reply With Quote Quick reply to this message
Unread 03-19-2010, 08:34 PM   #3
91wrangleryj
Ok, thanks. Should I push on the 'inside post' to let the fins collapse or pull from the outside? I want to reuse them if possible.
Unread 03-19-2010, 08:54 PM   #4
Opihi59
Opihi59's Avatar
User preference. I put the jaws of a pair of dikes behind the flat head, and squished the fins flat with a pair of bent needle nosed, and pushed/pulled til they came thru. You can re-mold the fins if they get mangled a bit by bending them back into position.
