Removing Exterior Door Handles - JeepForum.com
post #1 of 20 Old 09-10-2008, 11:09 AM Thread Starter
CheapSunglasses
2007 XK Commander
I'm trying to remove the exterior door handles on my '89 YJ full steel doors to paint them, and I can't seem to get those metal shims out....What am I doing wrong?....I can get them to move toward the top of the door, but they hit a part of the door and won't come all the way out....Anyone have this experience?
My next option is to leave them in and paint them, but I really want to get them out for a better job.
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #2 of 20 Old 09-10-2008, 02:37 PM Thread Starter
CheapSunglasses
2007 XK Commander
Anyone, Anyone....Bueller?....Anyone?
post #3 of 20 Old 09-10-2008, 03:52 PM
hockeynut9717
Remove the window scrubbers,inside and out. I managed to pull one out that way. I also used a piece of stiff wire to hook the retaining spring from the access hole under the door panel. Hook the clips and pop them off the teeth of the wedge. Than push ouy from underneath. You can reallign them when You reinstall. I replaced one last week. Its a pain in the butt.
Hope this helps
hockeynut9717 is offline
post #4 of 20 Old 09-10-2008, 05:53 PM Thread Starter
CheapSunglasses
2007 XK Commander
Hope this helps
I tried EXACTLY as you described....It's ridiculous how difficult these things are to get out
I was hoping I was doing something wrong.
post #5 of 20 Old 09-11-2008, 07:25 AM
Matt The Hammer
Loooong nose pliers.
Like the ones made by Klein Tools.
And A LOT of swearing...
Oh, waaaaaay easier to get the shims out....
2013 JKU
1995 YJ
Matt The Hammer is offline
post #6 of 20 Old 09-11-2008, 07:34 AM
vmann7
1987 YJ Wrangler
And a long flat head screwdriver to wedge/pound on when you get the right angles. They're a real PITA but with a little patience you'll get it.
vmann7 is online now
post #7 of 20 Old 09-11-2008, 10:05 AM
myyeep
anyone ever try to do door poppers on their jeep? speaking of removing exterior handles
myyeep is offline
post #8 of 20 Old 09-11-2008, 01:07 PM
ZeroGravity
Next time your at your auto parts store get a Haynes manual, too.
ZeroGravity is offline
post #9 of 20 Old 09-11-2008, 03:59 PM Thread Starter
CheapSunglasses
2007 XK Commander
Haynes manual does no good for these little tips....Experience does the trick.
post #10 of 20 Old 01-06-2009, 08:29 AM
TWISTED125
this somewhat goes along with this thread so here goes . . . my pass side window regulator? is frozen, wont budge as well as my exterior door handle is falling out, broken. I have a spare set of full doors sitting in my garage, i bring in a red pass side (screwed) and a black pass side (donor). so i need to get the window mechanisms as well as outer door handle off of the black door and onto the red door. This my friends is truly a PAIN IN THE ***. I started this 2 weeks ago. . . what do I have? 2 doors, 2 door panels, 2 inside handles, random screws, drops of blood in my living room and a Jeep with no doors in the garage. Can someone please direct me to a write up!? I have tried searching and this was about as close as I could get. And yes, I have a Haynes, not really helpful in this situation. ANY HELP APPRECIATED
TWISTED125 is offline
post #11 of 20 Old 01-06-2009, 11:43 AM
TWISTED125
bump .. . . anyone got anything??
post #12 of 20 Old 01-06-2009, 02:20 PM
Matt The Hammer
Did you start by removing the inside panels? To do what you want, you'll have to remove the vapor seal too.
These doors aren't hard to fix/rebuild but they are tricky. You need to open up the inside panel and it will all be there. The window regulator is just a simple gear. Frozen? I'll suggest that either some component is bent or the gear is jammed. Maybe both.
I haven't worked on my doors in a long time. I disasembled them for painting though and while it was difficult to do (no room inside door) it wasn't splitting an atom hard to figure out what went where and how it worked.
A Factory Service Manual is your friend. Even a diagram from a parts catalog would help you too. I don't have either to offer.
2013 JKU
1995 YJ
post #13 of 20 Old 01-06-2009, 02:57 PM
TWISTED125
ok, yea I took the inner panel off, I guess its just a lack of space that makes getting to this stuff so hard. In my Haynes it says to lower the window all the way down, but my window wont budge, maybe this is making it more difficult. thanks for the input
post #14 of 20 Old 01-06-2009, 03:43 PM
Leroux
Leroux's Avatar
I used a small nose punch and a hammer to get the metal clips out of mine.
'93 YJ 4.0 i6, 8.8ls, D30 w/Aussie & Alloy USA shafts/disco removed, 4.56's, 3.5" Fabtech (gathering parts for SOA), 5/8 MORE Boomerangs, SYE, Coast Driveshaft, m8000, "Accordion style" Header w/full exhaust, 33" Siped BFG MT's, TJ Flares.
Leroux is offline
post #15 of 20 Old 01-20-2009, 12:34 PM
SexySE
I'm having the same problem with mine. My driver's side handle is stuck in the pulled out position and won't return flush. Can't open the door from the outside. I bought new exterior handles and have no idea of how to get the old ones out.
'88 Jeep Wrangler YJ 4.2L 6 cyl Red/Gray soft top/Black hard top 3" Lift on 33s
'01 Nissan Sentra SE 2.0L 4 cyl Inferno/Charcoal Performance Package Dropped on 18s
'66 Ford Mustang Coupe 289 V8 Silver Blue Poly/Blue
SexySE is offline
Exterior Paddle Handles BigLou YJ Wrangler Technical Forum 10 02-14-2010 06:24 PM
Different with TJ exterior door handles? Mark_ZZ3 YJ Wrangler Technical Forum 0 12-13-2009 10:06 PM
where to get new exterior door handles??? TXjeepTJ TJ Wrangler Technical Forum 9 12-05-2007 09:04 AM
Removing door handles? DCGayhart TJ Wrangler Technical Forum 2 04-25-2007 07:49 PM
Removing Outer Door Handles On Full Doors? daren71 TJ Wrangler Technical Forum 6 03-10-2006 06:28 AM
