Removing Differential cover??? - Page 2 - JeepForum.com
post #16 of 23 Old 01-14-2007, 05:23 PM Thread Starter
theboxman71
theboxman71's Avatar
whats the best way to get the old gasket off???
1994 Jeep YJ SE Sport-UNDER CONSTRUCTION!!!
See it here
theboxman71 is offline
post #17 of 23 Old 01-14-2007, 07:05 PM
Burnerman
Burnerman's Avatar
Razorblade. I have a scraper that uses a single edge blade. It works great. It's hard to gouge the cast iron housing, but possible, so use caution. Carb cleaner or GOOF OFF helps get the small leftovers off. I used Blue Prematex RTV to reseal mine. No drips. I also used a can of brakecleaner to flush out all the old oil and junk from the housing. You can inspect the gear teeth and bearings better. Also you can see if theres any metal filings that may be glued to the bottom.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #18 of 23 Old 01-14-2007, 07:09 PM
bobbert350
bobbert350's Avatar
this stuff call gasket remover..works great never thought it would work that good..then just scrape with a razor blade..the gasket remover makes it easier
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #19 of 23 Old 01-14-2007, 08:48 PM Thread Starter
theboxman71
cool, ill use that brake cleaner idea...THX
See it here
post #20 of 23 Old 01-14-2007, 08:49 PM Thread Starter
theboxman71
THX man..
See it here
post #21 of 23 Old 04-24-2013, 02:49 PM
Bannerman53
just take all the bolts off and then drive it around until the cover falls off
Bannerman53 is offline
post #22 of 23 Old 04-24-2013, 03:30 PM
idaholtby
Awesome! I love it when a 6 year old thread is brought back to life!
It brings back memories otherwise killed off by the adult beverages.
idaholtby is offline
post #23 of 23 Old 04-26-2013, 10:23 PM
Flajeeper1
1987 YJ Wrangler
HOLY MOLY batman talk about resurrecting an old thread!
Flajeeper1 is offline
Differential Cover XDS22 TJ Wrangler Technical Forum 2 10-04-2007 09:10 PM
Removing front differential gear pasinbuy YJ Wrangler Technical Forum 13 05-26-2007 10:17 AM
8.8 Differential cover Tomb Raider YJ Wrangler Technical Forum 14 09-12-2006 08:46 AM
which differential cover bikerjeep TJ Wrangler Technical Forum 17 07-27-2005 03:00 PM
Removing bolts from differential cover? DLoweinc TJ Wrangler Technical Forum 6 03-03-2003 10:37 PM
