Removing Differential cover??? - JeepForum.com
post #1 of 23 Old 01-12-2007, 05:52 PM Thread Starter
theboxman71
theboxman71's Avatar
Any tips on how to get these babies off???mine aren't budging...tried everything...whats the secret???except getting a jeep with less RUST!!!
THX
1994 Jeep YJ SE Sport-UNDER CONSTRUCTION!!!
See it here
theboxman71 is offline
post #2 of 23 Old 01-12-2007, 05:56 PM
drexelsteve
After you remove the bolts you have to pry the cover off. There's no real trick to it, just go nice and easy with a flat blade screwdriver. Try not to mar up the surfaces if you can help it, but silicone usually seals them up no problem.
13 Rubi
drexelsteve is offline
post #3 of 23 Old 01-12-2007, 05:57 PM
bobbert350
bobbert350's Avatar
try hitting the cover with a minisledge with a block of wood inbetween..i tried to hit it so the cover would slide to one side
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #4 of 23 Old 01-12-2007, 06:01 PM
dell2028
dell2028's Avatar
Thin flathead screwdriver.
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline
post #5 of 23 Old 01-12-2007, 06:12 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
rubber mallet!
whack the ***** out of it side to side
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #6 of 23 Old 01-12-2007, 06:47 PM
atomicmoose
Just call me Moose
atomicmoose's Avatar
I use an old putty knife to get the split started, then I shove a flat head screwdriver in there and pry it apart. Rubber mallet works too.
atomicmoose is offline
post #7 of 23 Old 01-12-2007, 07:16 PM
kloppk
Originally Posted by Big-n-Broke-YJ
rubber mallet!
X2 Works every time
kloppk is offline
post #8 of 23 Old 01-12-2007, 07:19 PM
jeep couple
i used a putty knife to open mine up a little. I then let all the fluid drain out into a pan. I then used a rubber mallet hitting from side to side. It worked like a charm.
jeep couple is offline
post #9 of 23 Old 01-12-2007, 08:53 PM
Burnerman
Burnerman's Avatar
If it's the bolts that you can't get out try a handheld 3/8 impact driver. You put the proper 3/8 drive socket on it and hold it in one hand applying pressure in the direction you're going and whack it with a hammer. It pounds the socket on tighter and loosens in 1 movement, It is pretty impossible to strip or break off a bolt with it but they work for getting tough bolts and screws out.http://www.sjdiscounttools.com/otc4608.html
Like this. I don't have this one but they work the same.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #10 of 23 Old 01-13-2007, 10:18 PM
84 400
x3 on the rubber mallett
84 400 is offline
post #11 of 23 Old 01-14-2007, 10:54 AM Thread Starter
theboxman71
i got all bolts out no prob, seems to be rusted a little, gonna whack the s#$t out of it...
thx guys
See it here
post #12 of 23 Old 01-14-2007, 11:12 AM
bobbert350
bobbert350's Avatar
rubber mallet!
ahh next time il use that instead of a mini sledge...didnt even think of that i always use a wood block and the 3lb mini sledge..only reason is cauz they are close next time il try a rubber mallet
post #13 of 23 Old 01-14-2007, 01:38 PM
MY90YJ
good tools to own for jeep repair:
Impact Driver
Dead Blow Mallet, think rubber hammer but with more hitting strength
MY90YJ is offline
post #14 of 23 Old 01-14-2007, 06:10 PM Thread Starter
theboxman71
Got them off with screwdriver and rubber mallet, THX guys!!!
See it here
post #15 of 23 Old 01-14-2007, 06:19 PM
Tulsachokehold
for a second, I thauight those last pics were the inside of the voer and that you have lined it with RTV. I was thinking that you were crazy and or stupid. but then I realized it was the outside of the cover.
'91 YJ. 4.0 TF999, D300 w/ 4:1, twin sticks. Chevy D44 front, 4.10's, spooled, Yukon 4340 shafts w/ super joints. Warn premium lock outs, High steer, ram assist. Dodge D60HD rear, 4.10's, welded, disc brakes. SOA front w/ RE 1.5" SOA leaf packs. Custom 4 link rear w/16" fox air shocks, stretched to 110". 38x12.5x15 TSLs on crager Nomads w/ DIY beadlocks. Tolly Fab Tube fenders, rocker gaurds, cage. 15gal stainless steel fuel tank.
Tulsachokehold is offline
Differential Cover XDS22 TJ Wrangler Technical Forum 2 10-04-2007 10:10 PM
Removing front differential gear pasinbuy YJ Wrangler Technical Forum 13 05-26-2007 11:17 AM
8.8 Differential cover Tomb Raider YJ Wrangler Technical Forum 14 09-12-2006 09:46 AM
which differential cover bikerjeep TJ Wrangler Technical Forum 17 07-27-2005 04:00 PM
Removing bolts from differential cover? DLoweinc TJ Wrangler Technical Forum 6 03-03-2003 11:37 PM
