Removing Coil Over Lift ?? - JeepForum.com
post #1 of 5 Old 11-29-2011, 11:15 AM Thread Starter
jamisonmhopkins
Hey all, I have owned several Grand Cherokees but I am getting ready to purchase my first Wrangler. It is a 1995 YJ, 4.0, with a few things done to it already.
My question is this ... If I want to use the Jeep to drive on-road as well as off-road, should I be worried about the coil over lift? I have heard conflicting stories and figured that someone on here could set me straight.
Here is a list of what has been done to the Jeep so far ...
5 Inch Pro Comp Coilover Lift
35 12.50 General Mud Grabbers
Centerline Hellcat rims
Slotted rotors
Detroit Lockers front and rear
Strange 31 spline axles with 4:11 gears
SYE Kit with aftermarket driveshaft
New U-joints
Jet Computer Chip
Custom Intake
Jacobs Ignition system
Borla header and Borla cat back exhaust
Please let me know your thoughts. Again, I am new to Wranglers.
Thanks !!!
O|||||O
02, TJ, 4.0L, Auto, 3.5" RubiconExpress Lift, Bilstein Shocks, MT Classic Lock Black 15x8 Wheels, MT MTZ 33x12.50x15 Tires, Detroit TrueTracs F/R, 4.10 gears
jamisonmhopkins is offline
post #2 of 5 Old 11-29-2011, 11:56 AM
dillonjm
2013 WK
Adding coils or coil-overs would be an upgrade to the stock suspension if set up right. I assume its the 5" pro-comp coil suspension lift not coil-overs, not that it really matters.
If its just hacked together it may be a liability, but if they did it right it would be a "nicer" setup than leafs. IMHO.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #3 of 5 Old 11-29-2011, 12:35 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Slotted rotors
New U-joints
Jet Computer Chip
Custom Intake
Thanks !!!
Are you sure it's a 95?
The strange 31 spline axle is hopefully an 8.8.
Luck Favours The Prepared
Anticanman is offline
post #4 of 5 Old 11-29-2011, 12:37 PM
XtrailratedJ
Probably a spring over lift....But what do I know, I'm an XJ guy...
96 XJ 4.0L/AX15/NP231/AUSSIE'D D30/C8.25/4.5" RE LIFT/33'S/BUMPERS, SLIDERS, ETC...
"I pitty the fool who lists D30's and 31's, then tries to talk **** on PBB":
Originally Posted by Durt_Diver:
Those pics might be a little too flexy for this thread. You don't happen to have any pics of your friends xj on a curb by chance?
XtrailratedJ is offline
post #5 of 5 Old 11-29-2011, 02:27 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
If I were to be buying that YJ with the ProComp Coil Conversion kit, I'd remove the entire kit & either sell it to somebody who knows the history & real world manners of that kit, or toss it in the nearest dumpster/recycle bin.
Joe Dillard is offline
any hints re: removing/replacing ignition coil rail off 2000 4.0L? tw_jeep TJ Wrangler Technical Forum 9 01-25-2014 07:34 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 08:13 PM
Removing coil spacers from front, how to GMC7000 TJ Wrangler Technical Forum 12 05-23-2010 07:07 AM
Removing and painting coil springs cyberpunk TJ Wrangler Technical Forum 8 08-22-2007 12:49 PM
removing coil springs (the easy way) Texas TJ TJ Wrangler Technical Forum 11 01-20-2006 06:26 AM
