removing cat and replacing it with new one - JeepForum.com
post #1 of 25 Old 08-24-2011, 11:18 AM Thread Starter
comancheklein
ok i know this is prolly a way overasked question but here it goes..when removing my cat. the downpipe is not welded so i got that out but the section where the cat goes into the muffler is stuck not welded but rusted in. can i cut that with the sawzall and put a new one in or will the left over section inside the muffler area remain in and cause me problems if it does what should i do i got the clamps off and everything is ready i just need to remove the cat from the muffler and am trying to think of good ways how
2012 jku, manual,D30/D44, stock suspension
comancheklein is offline
post #2 of 25 Old 08-24-2011, 11:25 AM
TheNewbie
Just cut it.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 25 Old 08-24-2011, 11:35 AM Thread Starter
comancheklein
yeah but im not gonna weld it and im worried about that peice of the cat left in the muffler with that prevent me from putting the new one in easily?
post #4 of 25 Old 08-24-2011, 11:38 AM
TheNewbie
Peice of cat left in the muffler? There are several inches between the cat and muffler. Just cut it as close to the cat as you can.
post #5 of 25 Old 08-24-2011, 11:42 AM Thread Starter
comancheklein
huh? not on mine..it was obviously replaced and the cat runs directly into the muffler with the end of the cat. going into the start of the muffler
post #6 of 25 Old 08-24-2011, 11:45 AM
bogleparsons
Buy a flowmaster muffler $40 ans clamp it to downpipe
bogleparsons is offline
post #7 of 25 Old 08-24-2011, 11:52 AM
wanabejeeper
1987 YJ Wrangler
yep thats your best bet and probably what they did first time around.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
post #8 of 25 Old 08-24-2011, 11:57 AM
TheNewbie
OK, someone must have modified it then. On mine the muffler is lined up just about where the rear side of the skid plate ends. The cat is on the other side of the skid plate by the transmission.
Can you get a pic of the cat and muffler? It's hard to say what I'd do without seeing what's going on. If you can weld then it should be pretty easy. If not then there may be a way to save the mufler, or there may not.
post #9 of 25 Old 08-24-2011, 12:00 PM Thread Starter
comancheklein
i think i may be able to cut it but im trying to get pics up but things are being slowww
post #10 of 25 Old 08-24-2011, 12:17 PM
kahanabob
try tapping on the rusted area add a little light weight oil and a big pipe wrench on the neck of the CAT and try to work it loose????
kahanabob is offline
post #11 of 25 Old 08-24-2011, 06:38 PM Thread Starter
comancheklein
well i cut it and got rid of the cat now its gone and im happy thanks everyone
post #12 of 25 Old 08-24-2011, 07:25 PM
Missouribound
No vehicle inspections in your state? I had to put a cat back on my YJ to pass the inspection. Good Luck
Missouribound is offline
post #13 of 25 Old 08-24-2011, 08:03 PM
oldtime_ironman
The cat converter is a Federal law, so it doesn't matter what state you're in. If the vehicle had one originally, then it has to have it forever, even if they don't do a tailpipe sniff test on your inspection.
oldtime_ironman is offline
post #14 of 25 Old 08-25-2011, 05:14 AM
bogleparsons
True, but why would anyone check If your vehicle isn't subject to emission testing?
Anything in my state past 1996 is not subject to emissions.
post #15 of 25 Old 08-25-2011, 06:03 AM
purdueme06
I'm fairly new to the state, but I thought I had to get an emissions check recently to renew my plates?
purdueme06 is offline
Removing TC drop and replacing with MML and maybe Bl?? iceman123187 TJ Wrangler Technical Forum 7 03-01-2010 12:14 PM
4.2 replacing belt but removing AC what size? Projekt89 YJ Wrangler Technical Forum 1 08-15-2009 02:00 PM
Replacing and removing the hard top Ctskip YJ Wrangler Technical Forum 11 03-21-2008 06:00 PM
Tips on removing and replacing exhaust xltj TJ Wrangler Technical Forum 15 10-05-2007 09:50 AM
removing and replacing sport decals ....... illumin8em TJ Wrangler Technical Forum 2 12-13-2003 06:20 PM
