Removing Bearing Retainer - JeepForum.com
post #1 of 4 Old 04-30-2013, 10:51 PM Thread Starter
TA-YJ
Im in the middle of the slave cylinder swap on my ax5 and I cant figure out how to remove the bearing old bearing retainer. Is there a pry point or something that I am missing? Ive tried tapping it and trying to get a screw driver in there but the thing is on there tight. From what I can tell the only thing holding it on is the RTV between it and the case. Any thoughts?
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #2 of 4 Old 05-01-2013, 09:45 AM
Siva283
When I took it off the old trans it popped right off. I pulled the bolts and grabbed the snout with my hand.
Ask me how I know...
Siva283 is offline
post #3 of 4 Old 05-01-2013, 10:23 AM Thread Starter
TA-YJ
The bearing retainer Im trying to get off is for an internal slave so there is no snout...or anything else to grab on to for that matter. Ive tried vice grips in a bolt hole, but the metal is so soft it just messes it up.
1992 YJ 2.5L
TA-YJ is offline
post #4 of 4 Old 05-01-2013, 07:14 PM
4.7stroker
I would gently work a sharp wood chisel in there.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
