Removed Transfer Case, Auto Tranny Spilled fluid - JeepForum.com
post #1 of 4 Old 11-03-2013, 12:12 PM Thread Starter
idskot
My question is: how much do I know to put in? I checked the dip stick with the car off, and it said it was full. But that's obviously not with the torque converter filled.
Should I just start the car and keep checking it as it warms up?
idskot is offline
post #2 of 4 Old 11-03-2013, 01:32 PM
jokerchief462
Auto trans running in neutral warm it up. Cycle the shifter through the gears to get the pump circulating the fluid back to neutral and check level. Do this a couple of times.
Parking brake and block a wheel.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 4 Old 11-03-2013, 02:19 PM Thread Starter
idskot
Should I be safe running it when it has leaked out... I'm really not sure. Probably a quart or so of fluid?
idskot is offline
post #4 of 4 Old 11-04-2013, 12:12 AM
jred
Automatic Transmission
32RH 17.1 pints
30RH 7 quarts
42RLE 4 quarts
Credit: http://www.jeep4x4center.com/knowled...capacities.htm
I would say cycling through the gears while not moving would be ok just being 1/4 low. Don't stress the tranny, though.
jred is offline
