-   -   Removed Transfer Case, Auto Tranny Spilled fluid (http://www.jeepforum.com/forum/f12/removed-transfer-case-auto-tranny-spilled-fluid-1753506/)
idskot 11-03-2013 12:12 PM
My question is: how much do I know to put in? I checked the dip stick with the car off, and it said it was full. But that's obviously not with the torque converter filled.
Should I just start the car and keep checking it as it warms up?
jokerchief462 11-03-2013 01:32 PM
Auto trans running in neutral warm it up. Cycle the shifter through the gears to get the pump circulating the fluid back to neutral and check level. Do this a couple of times.
Parking brake and block a wheel.
Sent from underneath my Jeep
idskot 11-03-2013 02:19 PM
Should I be safe running it when it has leaked out... I'm really not sure. Probably a quart or so of fluid?
jred 11-04-2013 12:12 AM
Automatic Transmission
32RH 17.1 pints
30RH 7 quarts
42RLE 4 quarts
Credit: http://www.jeep4x4center.com/knowled...capacities.htm
I would say cycling through the gears while not moving would be ok just being 1/4 low. Don't stress the tranny, though.
The time now is 12:16 AM.
