Removed horn pad and the 3 screws underneath the horn pad - help
#1 | |
Jeep
I removed the horn pad and the 3 screws holding on the green plastic circle and 2 metal discs... I put them back together the same way and the horn goes off constantly. There is only a little push button underneath everything for the horn, and when I screw everything down it pushes the button down and there is no gap to push down to sound the horn. Is there a spring I am missing? I didn't see anything fly out. Anyone who can take a pic of their stock steering wheel with the horn pad removed would be great... or better yet, step by step instructions on re-assembling the part below the horn pad.
From bottom to top I have: 1. Flat metal disc 2. Round cup-like metal disc 3. Green plastic circle, and then three phillips screws holding all 3 in.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#2 |
You may have the metal piece upside down. I did that when I had mine off. The rounded part of the metal ring should come towards you, not towards the steering column. Check to see if that works. I think I am describing it correct....
Herculined, MC2100, Nuttered, 31" Mud Rovers |
#3 |
I've got one of those GT steering wheels and there is a spring that is simply taped to the button. Pushing the button connects the circuit to sound the horn. (Well, at least it use to do that for me....)
#4 |
The flat metal disc is the "spring". It sounds like you have it upside down, tear down and flip it over. Did the same thing when I replaced my turn signal switch.
#5 | |
Jeep
Works great now. Now I am all set to surprise my dad with a new black leather wrapped steering wheel and black horn pad (along with a whole new black interior). Thanks again guys ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
