Remove plastic sill protector? - JeepForum.com
post #1 of 11 Old 07-06-2007, 10:19 PM Thread Starter
FLAWLESS
I've got a '90 YJ and I am in the process of painting it. I am at a loss as to how or what is needed to get the plastic door sill protection off this thing.
I've tried heat, acetone, reducer, wax and grease remover and xylene as well as automotive goof off and nothing is working. I even gave sanding a go and it didn't work as well as the xylene.
Someone must have figured out how to get this stuff off............
Any ideas?
'93 ZJ, 242 swap, 6" and 32's
'90 YJ, work in progress.........
FLAWLESS is offline
post #2 of 11 Old 07-06-2007, 10:28 PM
Kimmy
Kimmy's Avatar
Are you talking about the plastic tape-like stuff where you would put an entry guard? If so, I removed mine with Goo-Gone and a plastic paint scraper. Yes, it seemed to take forever. Once the Goo-Gone soaks in, it does seem to help.
94 YJ - Almighty 4 banger - 47K Miles - Dana 30/35 - RE 2.5" Lift - 31x10.5 Dakota Definity's
Selling homes on and off the beaten path, from the seat of my Jeep.
White Jeep Club Member #929
What I do today is important because I'm exchanging a day of my life for it.
Kimmy is offline
post #3 of 11 Old 07-06-2007, 10:45 PM
Burnerman
Burnerman's Avatar
You could try a rubber eraser wheel. I used one to remove the old hood stickers. It took me 15 mins to remove them. The sill protector is thicker but it may work. It goes in a drill and is basically an eraser the size of a 3" grinding wheel.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #4 of 11 Old 07-06-2007, 10:51 PM Thread Starter
FLAWLESS
Yup thats it, the plastic tape like stuff, I put some more goo gone on it and let it sit over night.
I like the look of that eraser thing I can think of a ton of uses for a thing like that.......I hope I can find one!
FLAWLESS is offline
post #5 of 11 Old 07-06-2007, 10:57 PM
Burnerman
Burnerman's Avatar
Check a body shop or paint supplier. I borrowed that one from my mechanic buddy. The thing is amazing! It removed the decal and adhesive without any damage to the paint. Just don't hang in one spot too long, it gets hot.
96 ZJ.
post #6 of 11 Old 07-06-2007, 11:45 PM
tooblackdogs
tooblackdogs's Avatar
Try some 3M adhesive remover, I bought some at Carquest when I took the emblems off my Chevy truck and it worked well on these too.
Don't tell my wife how much that really cost!
tooblackdogs is offline
post #7 of 11 Old 07-07-2007, 05:37 AM
dave_dj1
a torch worked for me !
Wheel it like ya stole it!
dave_dj1 is offline
post #8 of 11 Old 07-07-2007, 08:41 AM
bobbert350
bobbert350's Avatar
i used a wire wheel i was painting it anyway took like 2 mins
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #9 of 11 Old 07-07-2007, 09:56 AM
timatoe
timatoe's Avatar
x2
10 CHAR
timatoe is offline
post #10 of 11 Old 07-07-2007, 06:52 PM
workn4livn
workn4livn's Avatar
Airplane stripper ( I think thats the right name) works great and fast.
workn4livn is offline
post #11 of 11 Old 07-07-2007, 07:58 PM
Ares
Ares's Avatar
Aircraft Adhesive Remover
And yes, it works freaking mericals
- Cameron
Ares is offline
How do I remove tailgate plastic? muddbutt TJ Wrangler Technical Forum 4 01-04-2010 09:10 PM
How to remove plastic rivets? 1222 JK Wrangler Technical Forum 10 11-12-2008 09:19 AM
How to remove plastic body armor? drew76 TJ Wrangler Technical Forum 20 03-29-2008 10:03 PM
How to remove the plastic air dam from your JK. JLH JK Wrangler Technical Forum 0 05-23-2007 08:21 PM
How to remove plastic from dash? treeofliberty TJ Wrangler Technical Forum 2 11-26-2005 07:05 PM
