relay bad? - JeepForum.com
post #1 of 2 Old 12-17-2011, 07:02 PM Thread Starter
tslroper
relay bad?
I have fog lights wired with a relay and while doing some electrical work on other things (@#$%#$ electric choke) under the hood I happened to goof around with the relay a moment and noticed that even with the switch off the relay puts out about 4v to the fog lights. When switched on it puts out roughly 12.5v as would be expected and the fog lights work normally. Is this normal or is my jeep hypochondria kicking in again? I did not get a chance to check the relay thoroughly with an ohm meter as i ran out of time, but can do so tomorrow if it helps. Also of note, I was checking between pole 87 and ground.
Thanks for the help, folks.
tslroper is offline
post #2 of 2 Old 12-17-2011, 08:14 PM
ROWA
ROWA's Avatar
tslroper,
Remove the relay and use a Ohm meter between the 30 and 87 terminal, you should see 0 Ohm's. If you find any Ohm reading this would indicate a bad relay.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
Delay in fuel pump relay when turn the key. .. Won't start til relay switches fisherman125 YJ Wrangler Technical Forum 16 08-24-2011 07:26 PM
Fuel pump relay bridged to A/C relay????? bigdog79 TJ Wrangler Technical Forum 0 08-06-2010 12:17 PM
ASD relay circuit and Fuel pump relay issue 2006_Sport TJ Wrangler Technical Forum 5 04-20-2010 01:21 PM
Headlight upgrade problem relay relay relay rallynut88 YJ Wrangler Technical Forum 8 04-21-2008 09:31 PM
Relay Festaman TJ Wrangler Technical Forum 9 12-25-2004 11:24 PM
