Rekey hard doors - JeepForum.com
post #1 of 9 Old 04-07-2007, 05:37 PM Thread Starter
1969cj5
Rekey hard doors
Anyone have any ideas / experience with new lock and keys for hard doors and a tailgate. The doors I have had the driver side drilled, and I dont have the keys anyway. No key for the tailgate either. Ideas appreciated
Chris
1969cj5 is offline
post #2 of 9 Old 04-07-2007, 07:17 PM
kloppk
You can buy new key & lock cylinders from Krage and Trailquest.
Just remove the old lock cylinders and put the new ones in.
Of course you'l have to have an extra key or two on your key ring.
I had to do this for a pair of used hard doors I bought for my YJ.
The PO didn't have the keys...
kloppk is offline
post #3 of 9 Old 04-08-2007, 04:07 PM Thread Starter
1969cj5
thanks
Well I am sort of embarressed, I went the easy way and posted, then searched and found what I needed. Jeep Doc has them for 24 per set plus shipping.
Thanks!
1969cj5 is offline
post #4 of 9 Old 04-08-2007, 04:45 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
swap in TJ lock cylinders and ignition cylinder so you can have a non directional key
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #5 of 9 Old 04-08-2007, 06:37 PM
timatoe
timatoe's Avatar
Hey Big, is there anything special needed to do this???? I only have one set of keys and they're so worn that if I had new ones cut they would probably never work. I've thought of doing this before but didn't know if they would fit ok.
Thanks,
Tim
timatoe is offline
post #6 of 9 Old 04-08-2007, 07:06 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
i haven't personally done it but last time i was at my local shop i was helping finish up some small stuff on a YJ they built for a customer and while i was doing something up front i noticed one of the guys installing a new ignition cylinder and he had a TJ key in it. he made it sound like it swapped right in. Later in the day I saw him installing new cylinders in the doors and tailgate and they all took the same key. it appeared to me as though it was a direct swap, but i can't be 100% sure..... i can be 100% sure it's possible and it looked easy though
post #7 of 9 Old 04-08-2007, 07:34 PM
timatoe
timatoe's Avatar
Cool thanks
timatoe is offline
post #8 of 9 Old 04-09-2007, 07:51 PM
pmeguy
My 91 YJ has non directional keys... so did my 92.
On my last Jeep, I had replacement half doors so the locks did not match the ignition and I didn't have the door key anyway. I talked to a locksmith in town and he told me he could re-key the doors to match the ignition but I never did it. S I guess you could order a set of three locks from Quadratec or whereever and have them keyed to match your ignition.
pmeguy is offline
post #9 of 9 Old 08-09-2011, 02:53 AM
kbrawlz
here is a video i made on keying all locks the same.
<iframe width="425" height="349" src="http://www.youtube.com/embed/-uv3GOfrWG4" frameborder="0" allowfullscreen></iframe>
or
http://youtu.be/-uv3GOfrWG4
i'm not good on forums, so we'll see if the video embedded itself
jeep or die
kbrawlz is offline
rekey lock cylinders Obcean2 YJ Wrangler Technical Forum 19 08-09-2011 08:00 AM
Need to rekey my doors... lj_wil TJ Wrangler Technical Forum 14 08-09-2011 02:52 AM
hard topw fulls doors vs soft top w half doors airdevil85 YJ Wrangler Technical Forum 5 01-13-2010 10:37 AM
rekey a TJ skinton TJ Wrangler Technical Forum 1 10-29-2008 01:14 PM
Buying TJ with hardtop & hard doors, but I want a soft top & half doors xxxxxxxxxxxxxxxxxxxgksspot TJ Wrangler Technical Forum 11 10-26-2003 09:16 AM
