Rehab Questions '87 YJ - JeepForum.com
post #1 of 1 Old 07-12-2001, 12:55 AM Thread Starter
kralinc
I am in the process of trying to rehab my '87 YJ, I've managed to pull it all apart and am in the process of deciding just what to do. I will be rebuilding the 6 cyl 258 engine and replacing all of the electrics (no more computer - just the basics). I need to know if I can use a factory terminated wiring kit for a CJ given that I am starting from scratch? In addition I want to get rid of the mickey mouse plastic dash that the YJ has and replace it with, again something simple, namely a blank CJ dash panel which I can then customize to my specs. Will the CJ dash fit the YJ tub? Also any ideas on a steering column? I kind of beat mine up in dismantling it. Should I try to replace the entire column or just the plastic ignition housing?
kralinc is offline
new 8.8, few questions goldswim5 TJ Wrangler Technical Forum 13 05-27-2008 08:39 PM
Rocker guard rehab joo TJ Wrangler Technical Forum 7 09-18-2007 01:45 PM
rehab job on 91 YJ ? gr8service YJ Wrangler Technical Forum 1 02-17-2006 07:34 PM
2 lug nut questions- Mickey Mouse kind of questions kaybone TJ Wrangler Technical Forum 2 05-04-2005 05:34 PM
Rehab alternator bearings? Rusted S-belt stuff question, too. JeremyCT YJ Wrangler Technical Forum 2 12-09-2004 07:33 PM
