Regearing - JeepForum.com
post #1 of 14 Old 02-14-2012, 02:40 PM Thread Starter
stcarter44
Regearing
Im looking at putting 4:88s into my yj with a Dana 30&35 and I'm not sure what this entitles.. In my buddies f350 super duty we had to replace the rear end and it wS just 4 bolts and all the gears I guess it was came out and we put a new one in.. Is it that simple in my yj?
where'd all my money go? oh yah i bought a jeep
stcarter44 is offline
post #2 of 14 Old 02-14-2012, 02:52 PM
scubamc
Nope. You have to set the backlash and a few more important things. Most will recommend not pending the money on the 35.
scubamc is offline
post #3 of 14 Old 02-14-2012, 03:01 PM
Andywear
Shops will charge between 1k-$1500.
If you take the axles off and take them to the shop it might be cheaper.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #4 of 14 Old 02-14-2012, 03:24 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Labor at a shop will be between $200 and $400 per axle to install gears.
Luck Favours The Prepared
Anticanman is offline
post #5 of 14 Old 02-14-2012, 03:33 PM Thread Starter
stcarter44
I've heard alot of people say go to a ford 8.8 with disc brakes? How is that for an install? Difficult ?
post #6 of 14 Old 02-14-2012, 03:37 PM
Andywear
The cost of living in Cali is suppose to be high, that price to regear would have me driving to Cali for all my auto work.
Andywear is offline
post #7 of 14 Old 02-14-2012, 03:39 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pretty easy to install once you see what you're doing. Spring perches driveline adapter brake lines and ebrake cables and shock mounts all need to be addressed to install it. Pinion angle will be set with the spring perches. It's a lot easier than what people make it out to be.
post #8 of 14 Old 02-14-2012, 03:43 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's more a matter of shopping around and doing business with the folks that need the business. Times are tough and shops need work and if you're willing to be a nice guy and send them some work then they can usually cut you a deal. If not, you need to work on your negotiating skills.
post #9 of 14 Old 02-16-2012, 11:41 AM
crawler091
35's are bad mkay
take the advice on the 35 before you spend a whole paycheck on it and get something else. I dropped a 97 Taco 8" with new gears and detroit for $400 AND, it is bolt in if your SOA. if not just weld on perches, get an adapter ($25) and your good to go. Brake lines fit right up.
crawler091 is offline
post #10 of 14 Old 02-16-2012, 03:13 PM
jbeebe
x10 on not regearing the d35. use the search function for a thousand threads on swapping in a 8.8
jbeebe is offline
post #11 of 14 Old 02-16-2012, 07:03 PM
Ryno_XJ
I am also preparing to do 4.88s but in a dana30 front and 8.8 rear. I got the 8.8 for $150 and the gears and install kits all for $465. Not a bad deal for a set up that will last me for probably the life of my YJ and possibly more!
Like others have said, do not throw money at the turdy5, they have been known to break even when not wheeled. Shop around for a good price on an 8.8. It obviously depends on the area, but they go for anywhere between $75-$250 around here, and most of them are in the $150 range.
Ryno_XJ is offline
post #12 of 14 Old 02-16-2012, 07:05 PM
Ryno_XJ
Double post.
Ryno_XJ is offline
post #13 of 14 Old 02-17-2012, 09:13 PM
plumber1
WOW I need to get the number of your gear guy, I paid double those prices. But maybe the valley is cheaper than the Bay Area.
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #14 of 14 Old 02-17-2012, 10:53 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I got quotes from three places here and those were the numbers I came up with at different times of the year and one or two axles brought to them. I spent some time to go inside and talk to some of them face to face and got a better price.
Regearing jlarsen2 YJ Wrangler Technical Forum 2 11-13-2008 10:57 AM
regearing AZrattled JK Wrangler Technical Forum 15 08-08-2008 01:50 PM
Regearing?? TJeep97 TJ Wrangler Technical Forum 13 10-24-2007 12:09 PM
DIY regearing? novocaine JK Wrangler Technical Forum 9 09-19-2007 07:51 PM
Regearing angryjohnny TJ Wrangler Technical Forum 5 08-04-2007 11:53 AM
