REGEAR Question on Ford 8.8 - JeepForum.com
post #1 of 22 Old 07-24-2006, 10:08 AM Thread Starter
daddoty
Well I found a Ford 8.8 rearend and it has 3:73 limited slip. Can I have 4:88 gears put in and still use the linited slip? With the off set compared to the dana 35 do i need a cv shaft?
daddoty is offline
post #2 of 22 Old 07-24-2006, 10:19 AM
Leroux
Leroux's Avatar
Yes, you can install 4.88 and still have LS. I dont think you "need" a SYE, but it would defiantly be a good thing.
'93 YJ 4.0 i6, 8.8ls, D30 w/Aussie & Alloy USA shafts/disco removed, 4.56's, 3.5" Fabtech (gathering parts for SOA), 5/8 MORE Boomerangs, SYE, Coast Driveshaft, m8000, "Accordion style" Header w/full exhaust, 33" Siped BFG MT's, TJ Flares.
Leroux is offline
post #3 of 22 Old 07-24-2006, 10:44 AM Thread Starter
daddoty
thanks for your response
I followed your advise and got this 8.8 and it should be well worth it. I checked around and it would only be a matter of time before the old dana failed.
daddoty is offline
post #4 of 22 Old 07-24-2006, 11:11 AM
Leroux
Leroux's Avatar
Good job! You'll be happy with it. How much did you end up paying for it?
Leroux is offline
post #5 of 22 Old 07-24-2006, 12:34 PM Thread Starter
daddoty
490.00 it has disc brakes but no rotors. I also ordered the bracket kit to make things easier.
daddoty is offline
post #6 of 22 Old 07-24-2006, 12:47 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
That's too bad. There's TONS of them available on this website in FL for $300 or less.
http://www.car-part.com/
Joe Dillard is offline
post #7 of 22 Old 07-24-2006, 12:53 PM
pushead
OMG that was high. I spent $270 with taxes and it came with disc and calipers.
Its not a jeep if it dont have 4wd.
pushead is offline
post #8 of 22 Old 07-24-2006, 08:08 PM
drexelsteve
wonder how many people are gonna chime in that you paid too much for the 8.8...
13 Rubi
drexelsteve is offline
post #9 of 22 Old 07-24-2006, 08:48 PM
Joe Dillard
I did so in an effort to warn others and hopefully save others some $ in the future, and showed them just one easy way to do so.
post #10 of 22 Old 07-24-2006, 10:27 PM
DaemonJeep
paid $350 for mine brand new, never been installed in anything, it was surplus stuff, 4.10 gearing open carrier. Pads rotors and calipers but no brake lines.
Hey who cares what I got, it goes through mud, that's all that matters!!
DaemonJeep is offline
post #11 of 22 Old 07-24-2006, 11:23 PM
jipjip
jipjip's Avatar
who cares how much was paid......they are gonna differ in price depending on a lot of things, as long as you didn't pay over $500 you got a pretty good deal. it also depends where you are in the country. popular demand areas charge more for the rears.
congrats on the new rear-end, but i don't think you can use the carrier that came w/ it for 4.88's. their are 2 splits in carrier styles between gears that if you re-gear to that ratio, you may need to replace the carrier also. that will also mean loosing the lsd. i wouldn't worry about it though, cause while your re-gearing, you might as well install a locker at the same time, it's much better off road, and won't bother your on road comfort too much.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #12 of 22 Old 07-25-2006, 12:33 AM
Stangman516
Where'd you find that?
'95 Mustang GT
'91 YJ 4.0L
/l ,[____],
l---L--?lllllll?-
()_) ()_)----)_)
White Jeep club member #40
Stangman516 is offline
post #13 of 22 Old 07-25-2006, 06:57 AM
DaemonJeep
A local race shop had two, they were surplus when Ford changed Exploder to IRS.
I agree doesn't matter what you paid, as long as you got what you needed, crazy how prices vary through out the U.S. And I'd find some good info on doing gear changes and do it yourself if possible, save ya a bunch of money, and you'll know how to do it for extra side cash to pay for them new gears and such.
post #14 of 22 Old 07-25-2006, 09:31 AM
Joe Dillard
Originally Posted by jipjip
<snip> congrats on the new rear-end, but i don't think you can use the carrier that came w/ it for 4.88's. their are 2 splits in carrier styles between gears that if you re-gear to that ratio, you may need to replace the carrier also. that will also mean loosing the lsd. i wouldn't worry about it though, cause while your re-gearing, you might as well install a locker at the same time, it's much better off road, and won't bother your on road comfort too much.
Hmm, the 8.8 doesn't have a carrier break - not sure where you got that tidbit of misinformation, or what caused you to *think* it did.
post #15 of 22 Old 07-25-2006, 10:50 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Exactly like Joe Dillard said...
There is no carrier break with the 8.8.
Just be aware that with 4.88 gears, you'll need to shave the ring gear or use a notched cross pin. There are notched cross pins available from most drivetrain vendors or you can grind down the stock pin.
Wheelin98TJ is offline
Regear Question WindyCityGuy TJ Wrangler Technical Forum 6 05-09-2008 07:26 AM
Regear Question? jcm11881 TJ Wrangler Technical Forum 4 01-21-2007 10:42 AM
Yet Another Regear Question Brett327 TJ Wrangler Technical Forum 5 07-21-2004 01:08 PM
Yet another Regear question 93 Blue Demon YJ YJ Wrangler Technical Forum 1 05-06-2002 11:03 PM
