regear or new axles? - JeepForum.com
post #1 of 4 Old 06-04-2002, 12:26 AM Thread Starter
93 Blue Demon YJ
Well I know what its like to have a 2.5 4cyl now. I have a 4.0, but recently put 32's on. I have 3.55 gears, and the power is still acceptable, but I really miss the power I used to have. I didnt realize that the labor of getting regeared was so high. Its kinda silly if you think about it, getting regeard costs as much as my lift and new wheels combined. I wish I knew something about axles so I could do it myself. Anyway, I was thinking maybe it would be best to find some used 4 cyl yj axles (which all have 4.10's) and install them, and could possibly make a few bucks back on my old ones. What do yall think? THX
Richard
'93 YJ 4.0 3" RC lift 15x10 wheels and 32" tires.
93 Blue Demon YJ is offline
post #2 of 4 Old 06-04-2002, 11:06 AM
Skeeter
You right! but when you regear it is a good time to add that locker you always wanted. Just a thought!
Skeeter is offline
post #3 of 4 Old 06-04-2002, 02:01 PM
slacker
I think you should start keeping an eye out for some used axles.
If you're not in a rush and depending on your longer-range goals, I think there are some pretty decent deals out there...folks higher up on the food chain are always upgrading and yards get new stuff.
I recently picked up a complete 8.8 from a 2000 Explorer with 4.10 gears for $550 at one junkyard and found an d30 from a '95 4 cyl. with 4.10 gears and the bigger ujoints for $450 at another yard. That shop also threw in the drag link and tierod so now I have spares.
I've been told I should be able to get anywhere from $250-400 for my d35 which should offset most if not all of my labor charges.
Good luck.
'07 WK Limited, 3.0 CRD, OME lift (current)
slacker is offline
post #4 of 4 Old 06-04-2002, 04:59 PM
BzJeep
BzJeep's Avatar
<a href="http://www.drivetraindirect.com" target="_blank">www.drivetraindirect.com</a>
On the left should be a link that says "Packages"
It has a Gear Set Of 4.11/4.10 For only 429.99
Thats what im going to get. It comes will all the stuff nessecary for a regear.
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
Regear or New Axles 442Wrangler TJ Wrangler Technical Forum 9 10-12-2009 12:03 PM
Would it be cheaper to regear or add new axles chaznad TJ Wrangler Technical Forum 6 02-28-2009 09:54 PM
94 axles to 91 Axles Brake issue???? lawson1273 YJ Wrangler Technical Forum 1 12-13-2008 10:10 AM
Do i need to regear both my axles? Help a newb! drummerdude1234 TJ Wrangler Technical Forum 13 11-29-2008 12:52 AM
Regear Stock Axles MUDDYJEEP YJ Wrangler Technical Forum 31 04-17-2008 09:13 AM
