Regear.... - JeepForum.com
post #1 of 3 Old 01-22-2002, 07:42 PM Thread Starter
Trucidus Sum
Regear....
0000000000000000000000
Trucidus Sum is offline
post #2 of 3 Old 01-22-2002, 07:59 PM
bob91yj
You don't say what engine, for a 6 cylinder I'd go 4.56's, and for a 4 cylinder 4.88's. 35's is really pushing the limits on stock axles. 33's and a 1" Daystar body lift would be much better. There's nothing good about a 3" body lift in my opinion.
Regearing is definitely better left to the pros, if you have to ask, I wouldn't even consider attempting it.
I can pick my way over a trail with the guys on 35-37" tires on my 33's as I'm on stock axles, and don't have those huge pumpkins to drag over everything. <damn I wish I had that problem>
If you're really gonna go with 35's, carry spare axle shafts with you.
Bob
91YJ Sahara, SOA, 4.88's, 35's, Locked
bob91yj is offline
post #3 of 3 Old 01-22-2002, 08:02 PM
igofshn
Locked @ both ends
igofshn's Avatar
No you cannot do the work by your self. It is not for the beginner mechanic, unless you want to screw it all up. A shop will charge you around $1000 for both axels. I assume you have a 2.5, if so you probably want to go to 4.88's to keep the power band.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
4.56 Regear cragrat TJ Wrangler Technical Forum 2 09-22-2009 04:02 PM
Do i need to regear? jeepin-gheenoe TJ Wrangler Technical Forum 7 07-06-2009 07:38 AM
Regear Q's renegadeyj YJ Wrangler Technical Forum 10 10-27-2006 12:57 AM
33s or 35s W/O regear blacktj27 TJ Wrangler Technical Forum 38 10-16-2006 11:29 AM
ReGear, Let's try again wriver82 TJ Wrangler Technical Forum 11 09-23-2005 09:45 PM
