Refusing to go over 65mph - JeepForum.com
post #1 of 41 Old 07-25-2013, 07:14 AM Thread Starter
whiskeywiz
I have a "found on the floor" Holley carb on my 258, (89 wrangler) which was made in 1980 for a Dodge 318 that the previous owner threw on for a quick sale. The wiring and vacuum lines are all jacked up but i think this issue is beyond that. Anyway, ive been blaming the carb all along for it falling on its face when i go beyond that sweet spot on the pedal. Well, after doing a head job i thought hey, lets shoot some carb cleaner in there and see what happens. Holy crap it's running like a raped ape! All response, all rpm's! EXCEPT... for when i get in 5th gear I cant cross 65mph. It jerks and barks back at me. Im thinking maybe timing? I plan on getting a new carb of course, just want an easy fix so i can enjoy it for the rest of the season. Thanks for PRACTICAL suggestions! (no vacuum psi or crankcase pressure revolutions type suggestions needed)!
whiskeywiz is offline
post #2 of 41 Old 07-25-2013, 07:52 AM
pasinbuy
Your profile states that you do not have tires. What size tire do have?
pasinbuy is offline
post #3 of 41 Old 07-25-2013, 07:58 AM Thread Starter
whiskeywiz
31's
post #4 of 41 Old 07-25-2013, 11:48 AM
dancytron
Has the Nutter bypass been done yet? http://www.jeepforum.com/forum/f8/ho...bypass-522262/ If not, the computer must be freaking out and could be a big part of the problem.
dancytron is offline
post #5 of 41 Old 07-25-2013, 03:35 PM Thread Starter
whiskeywiz
just got home and threw the timing light on it... guess what... THE MARK WAS OFF THE SCALE! My oh my im really tuning this thing in. If i ever see the PO again....
Will scope out that nutter thing later tonight, tnx.
post #6 of 41 Old 07-25-2013, 04:13 PM Thread Starter
whiskeywiz
oops, did not disconnect the vacuum advance. doh!
post #7 of 41 Old 07-25-2013, 07:09 PM Thread Starter
whiskeywiz
well it seems a lil better after adjusting the timing, but is still present. Looking around the engine, I appear to be missing a lot of stuff. I do not see an egr valve, the CTO sensor is capped off completely, etc etc...
So I am going to go in another direction and look for just what exactly should be inside my engine compartment. Then I will work on verifying electrical connections and especially vacuum connections. I have the serial number off the block and so far am not having any internet luck.
I also found Jeep's website where you can enter your vin number for wiring manuals, body repair manuals, owner manuals, etc... But it's telling me that I am entering an invalid VIN. wtf!
post #8 of 41 Old 07-25-2013, 07:45 PM
dancytron
This will show you all the stuff that was once under there. http://home.sprynet.com/~dale02/list.htm
You'll never get it back to that.
This shows you what is controlled by the computer and what isn't. http://home.sprynet.com/~dale02/control.htm
This kind of explains the Nutter bypass. http://home.sprynet.com/~dale02/ignmods.htm (click on each picture)
post #9 of 41 Old 07-25-2013, 09:17 PM Thread Starter
whiskeywiz
Impressive
post #10 of 41 Old 07-25-2013, 09:49 PM Thread Starter
whiskeywiz
This is just what I was looking for. Thank you very much! What it means however, is not what I was looking for. This means that the PO had the motor rebuilt, (good), but threw out all the useless parts rather than installing them. Not to mention reconnecting any of the wiring.
Well I think ill probably take any bolt ons off of the engine and start getting that thing to resemble the picture. No sense in trying to diagnose performance issues when all the sensors are missing and over half of the electrical and vacuum are dead end connections. Thanks again for the link. Whoever made that spent some hours.
post #11 of 41 Old 07-25-2013, 10:22 PM
dancytron
Basically, what you've got to do is fix all the vacuum leaks, do the Nutter bypass and then tune it like it is a 1979. A factory service manual for a 1979 or earlier CJ7 would be a big help.
Post some pictures and try to get Old4x's attention.
post #12 of 41 Old 07-26-2013, 09:04 AM Thread Starter
whiskeywiz
now you are raising a tad bit of concern with your use of "1979". Is that a typo? I am 1989 Wrangler. 258 I6. I have the engine model number somewhere if need.
tnx
post #13 of 41 Old 07-26-2013, 09:07 AM Thread Starter
whiskeywiz
also, i can punch in my vin on Jeep.com and get all kinds of goodies like wiring catalog, body part replacement procedure catalog, etc. However the site wont recognize my vin. Probably too old. Which sucks cuz those would have been great service manuals. Haynes isnt cutting it for me on this project. I n Haynes I get alot of "If Equiped" statements, where i need to know "If Equiped".
post #14 of 41 Old 07-26-2013, 09:36 AM
dancytron
Yeah, 1979. When they added the computerized emissions sometime in the early 80's, they just added more stuff (computerized timing, a computerized carb and all the sensors etc) on top of the old engine. The old 1979 or so engine is still underneath there.
For the computerized system to work right, it all has to be there and working right. That's never going to happen for you.
So, do the Nutter bypass (which bypasses the computer) and then tune it like it is a 1979. It is what lots of people do. Mine was totally stock and had all the parts when I bought it, but hadn't been maintained, so that's what I did. It had very similar symptoms to yours, which I suspect was a failed knock sensor among other things.
When you get to do the tuneup part, use better Ford parts. http://www.jeepforum.com/forum/f8/i-...nitive-669495/
The 1970's ones did have the CTO, Vapor Canister and EGR valve. I'd try to put those back if it was me, because I care about the environment if it is only a hundred dollars or so, but others will have different opinions. But get it running right first.
Many manuals here. http://www.jeep4x4center.com/knowledge-base/
Another viable choice is to buy the kit and convert it to TBI fuel injection or do the junkyard parts equivalent. I have no first hand experience with that. But you'll never get the stock system to work without the stock carb and an unbelievable amount of screwing with it.
post #15 of 41 Old 07-26-2013, 10:14 AM Thread Starter
whiskeywiz
Yup, you got it... i actually broke the knock sensor when i did the head job last weekend, (see my post called Nut in the Carberator).
