Redesigning Center Dash Panel... any Tips? - JeepForum.com
post #1 of 3 Old 11-14-2011, 04:14 PM Thread Starter
CouchYJ
I just bought a stock YJ about a month ago and I've been slowly finding time to modify interior things. In the spring when I can use another vehicle as my DD I'll take the time to do exterior / mechanical mods. Right now the dashboard design is really getting on my nerves.
I took the plastic cover off the center dashboard just to see how much space there is to change things around. I know that I'll have to take the rest of the dashboard apart to do this but I was hoping to do was flip the HVAC panel and stereo locations, move the gauges around and find room to install a CB.
If it doesn't turn out practical to mount the CB in the dash I plan to simply fab an overhead CB rack with a shelf track and some U-Bolts. If anyone has any tips or photos from changing their dashboard please share them!
[ʭlllllllʭ]
CouchYJ is offline
post #2 of 3 Old 11-14-2011, 04:22 PM
Spuznick242
Hmmm. I never designed a dash before but I'm uber intrested and I really want to see what turns out. Take a buncha pics and do a write up or build thread to keep us updated.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #3 of 3 Old 11-14-2011, 06:10 PM
Dre40
well if you can weld check out what I did.. click below.
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
cb , dash , radio , stereo , YJ
Tips/Suggestions: Wiring in a second fuse panel MacK JK Wrangler Technical Forum 2 04-10-2011 02:40 PM
Any tips on fixing rocker panel damage? spshultz YJ Wrangler Technical Forum 10 11-06-2010 08:44 AM
Removing Center Dash Panel KevinKrupp TJ Wrangler Technical Forum 3 08-15-2007 04:09 PM
Center Dash Clips...Cant Find? or a new center dash CollinJD TJ Wrangler Technical Forum 5 09-30-2006 10:12 PM
Rocker panel install tips please Jeepsport TJ Wrangler Technical Forum 12 01-09-2003 10:18 PM
