Recommendation about lockers? - Page 2 - JeepForum.com
post #16 of 35 Old 04-21-2010, 10:54 PM Thread Starter
danieljeep88
So you will go with an auto 100% rear? Why wouldnīt you go 100% up front and selectable in the rear? Donīt get me wrong , itīs a educate me question haha
danieljeep88 is offline
post #17 of 35 Old 04-21-2010, 11:23 PM
burnout189
well, mainly because i cant afford two selectables .
IMO, locking the steering axle would make for difficulty in turns. especially if you drive in snow.
- first thing, if your on it enough to lock it up, you could "go strait when you turn." (in 4wd, on snow/ice of course)
- second thing, it makes tight turns on trails slightly more difficult
- third thing, when off camber, if it should decide to spin, it could make you slide to the side.
the auto locker out back can have some of the same effects, but to me it would be much more noticable in the steering axle
this is only my opinion, as im sure some people will disagree with me.
you simply have to choose your battles, or break the bank and buy 2 ARB's.
BARNHART'S AUTO REPAIR
burnout189 is offline
post #18 of 35 Old 04-21-2010, 11:39 PM
ugmo
A locker in the front does not do well in slippery conditions (ie mud, snow, ice). I have my front locked and a lsd in the rear. The rear lsd will be replaced w/ a locker. As an fyi, my old jeep had a locked rear and open front and that combo worked well in all conditions.
I'm going to replace the lsd in the rear for sure, but uncertain about the front (although I'm really considering removing the aussie). A couple weeks ago, I ran into some serious mud while the surface looked completely dry (thanks, mojave desert) and the front locker dragged me deeper to the side while the rear lsd did nothing useful. When the front is locked, you get horrible steering in those types of situations.
If you have $1k, then do a detroit; if you have limited funds like everyone else, then an aussie will work just fine.
ugmo is offline
post #19 of 35 Old 04-21-2010, 11:48 PM
burnout189
more like $500. still not cheap, by all means. but not a grand either......
post #20 of 35 Old 04-21-2010, 11:49 PM Thread Starter
danieljeep88
Thanks to all of you , I have two buddyīs with detroit auto 100% in the rear they say itīs the best thing they have done but another buddy ho drove it said it a pain in *****. So I am very confuse actually I have 400$ to spend for the rear locker.... I have like 2 weeks in this confusing topic..
post #21 of 35 Old 04-21-2010, 11:53 PM
burnout189
well any "locker" is going to have quirks, wich to some may be a PITA. however, i can pretty much promise you, that if he doesnt like the detroit, he would really not like the aussie.
an lsd might help, but its not a locker. if you start to sway towards the lsd side, check out the true-trac.
damn, if i keep this up detroit locker is going to give me a job offer
edit: if you decide to look at a true trac, check, check, check prices. lots of places try to sell them for $600 + but one can be had for around $350-400 if you look hard enough. i dont know why that is...
post #22 of 35 Old 04-22-2010, 12:04 AM
Axl Jack
From your profile I see you are from Virginia. So, chances are you rarely see much snow.
That being mentioned, since you said you were on a budget why not do the following: Get an Aussie or LockRight or similar for the front. Try that out for a while. If that isn't enough for you, then you can save up for a selectable rear.
Once again, being that you live in VA you have the benefit of not seeing that much snowfall. So you might not even mind a lunchbox rear. It will chirp around corners a bit when on the skinny pedal, but if you're on dry pavement then who cares. (Since you don't have a D35 you don't have to worry about it imploding on the street.)
Personally, I'm going to leave my rear LSD for the time being and put an Aussie up front, but thats only because of two reasons:
1) PA sees a little bit more of snowfall every year
2) Can't afford selectable, and since my 8.8 is LSD I would have to swap to an open carrier, reset R&P anyway (something I don't know how to do yet). So until I learn how, leaving LSD in the rear.
Think about the type of offroading you do. Do you really NEED locked front and rear, or are you falling into the trap of thinking that because all the "serious" offroaders are locked F&R that you need to be too. Once again, personally for the type of offroading I do, all I need is a front locker for 90% of the wheeling I do. Sure, I'd love to be locked F&R when I visit Rausch Creek, but the two trips I plan on making this summer don't justify the added cost.
If you really want to know how a lunchbox rear handles in snow, you should be asking the people who live in the higher latitude states like Colorado, Montana, Wisconsin, Minnesota, Vermont, Maine, or those who live in Canada, etc.
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #23 of 35 Old 04-22-2010, 12:12 AM
OnlynAYJ
I've been running the Spartan locker for some time now in the front and have been quite pleased with it...It is very comparable to the Aussie or Lock Right, in performance and price. The install is fairly simple, I've heard that the design simplifies the install, but as I have never installed an Aussie or Lock Right I can't really testify to that. The only negative thing I could say about it, if you would even consider this negative, is that it tends to be a little louder than the Aussie or Lock Right.HTH
75% of the planet is covered by water. The rest is covered by Jeep
OnlynAYJ is offline
post #24 of 35 Old 04-22-2010, 05:29 AM
chupacabrah
chupacabrah's Avatar
I have aussies front and rear. The rear pops and clicks and things, but it's really not bad--you just have to learn how to handle it.
I don't know the aussie in the front is even there until I am in 4wd
That being said, they both do well and I'm glad I have them. If I was getting a rear locker now, I would probably get the detroit--go ahead and get rid of that weak 8.8 carrier.
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
chupacabrah is offline
post #25 of 35 Old 04-22-2010, 06:28 AM
hesserdude07
i been looking for a front locker for my D30 since i did my 8.8 rear swap. I welded my spiders in my 8.8 as its cheap, as thing as a spool and Detroits i dont like.... to many bad day! Only problem ive run into is trying to figure out what locker i want for the front so i been loving this thread!!
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #26 of 35 Old 04-22-2010, 06:39 AM
Karma
HI,
I keep saying the same thing and keep being ignored. Buy ARB. In my experience both with my Jeep and others, ARB's are the best game in town. Yes, they are a bit expensive. But they are VERY effective, very reliable, and can locked or unlocked instantly with the push of a button in response to trail or road conditions. I think they are the best.
But like all lockers in the front, they still don't steer worth a sh** when locked. That's why it is nice to be able to instantly unlock them. There is no way around this quirk with front lockers.
Sparky
Karma is offline
post #27 of 35 Old 04-22-2010, 09:59 AM
YJMonster
+1 for ausie lockers, my brother runs them front and rear in his yota. He drives 2 work everyday on the street and freeway with no problems. he is also able to do pretty much anything at the hammers here in socal.
2000 xj 4.5 Rubicon Express extreme duty(sold)
1988 yj 2.5 RC lift, 1/2 boom shackles- My baby
YJMonster is offline
post #28 of 35 Old 04-22-2010, 11:32 AM
MLJeeper
MLJeeper's Avatar
I run a detroit in the rear and i do love the function, its strong and locks every time. Its a beast. But its loud. The clicking gets old to me. If i had it to do over again, i would probably go selectable. As others have said, the aussie in the front is pretty much invisible on the highway.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #29 of 35 Old 04-22-2010, 01:31 PM
ugmo
Installed? No.
Most people can do a lunchbox type without help, but a Detroit carrier replacement type will generally add on labor costs.
ugmo is offline
post #30 of 35 Old 04-22-2010, 02:27 PM
Toms87
1987 YJ Wrangler
Aussies front and rear on jeep and explorer, 100% recommended
Toms87 is offline
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 05:37 PM
Help please - Oil recommendation Coyotes97 TJ Wrangler Technical Forum 1 02-19-2010 05:06 PM
Recommendation(S) digizure YJ Wrangler Technical Forum 17 02-13-2010 05:16 PM
Need recommendation Mamas Jeep YJ Wrangler Technical Forum 10 04-02-2008 02:58 PM
Lockers in front, lockers in back biffstephens TJ Wrangler Technical Forum 30 12-04-2004 03:45 PM
