Recommendation about lockers? - JeepForum.com
post #1 of 35 Old 04-21-2010, 05:28 PM Thread Starter
danieljeep88
I know... I know it has been spoken a lot ! I did a lot of research but didnīt find an answer.
I have rear D44 and front D30 I am thinking about lockers , since I am on a budget I cant afford a selectable one.
So the question is... What type and brand of auto lockers do you prefer and why? If you do 70% on road and 30% off road and you drive fast what would you do?
I read good things about spartan lockers. I was thinking a lsd for the rear and an aussie for the front.
Thanks!
danieljeep88 is offline
post #2 of 35 Old 04-21-2010, 05:32 PM
MLJeeper
MLJeeper's Avatar
LSDs blow for rock climbing, would be ok for leaf looking. Aussie would be my choice if your going with a lunchbox style locker.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #3 of 35 Old 04-21-2010, 05:32 PM Thread Starter
danieljeep88
Ohh and wich one makes less noises ..
post #4 of 35 Old 04-21-2010, 05:34 PM
provinT13
Forget about lsd's. Aussies are very popular, cheap, and known for quality. But if you do that much on road driving, I would only do an aussie up front and save for a selectable in the rear
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #5 of 35 Old 04-21-2010, 05:34 PM
MLJeeper
MLJeeper's Avatar
Any autolocker is going to make some noise. They are all about the same there as far as i know.
MLJeeper is offline
post #6 of 35 Old 04-21-2010, 05:35 PM Thread Starter
danieljeep88
I donīt do too much crawling I do more mudd. I understand that LSD works good in pavement and activates when one tire start spinning am I correct? In the other hand an auto locker would prevent the tire spinning right?
post #7 of 35 Old 04-21-2010, 05:40 PM
KA24DET95
I have the Ected locker by Auburn in my 06 GMC 1500 it has never failed. As far as noise is concerned I could not tell you b/c i have 33" Nitto mud graplers. nothing in my YJ yet.
KA24DET95 is offline
post #8 of 35 Old 04-21-2010, 05:40 PM
MLJeeper
MLJeeper's Avatar
Locker distributes the torque equally. Both wheels turn same speed.
LSD distributes the torque with bias toward the wheel with the least amount of traction. LSDs do alright in mud.
MLJeeper is offline
post #9 of 35 Old 04-21-2010, 08:02 PM
yellow2kgt
My YJ is not my DD but it is used on road when it snows. With that in mind I was a little afraid of an auto locker. I ended up with an Eaton E-Locker for the D30 and a rebuilt LS for the 8.8. I ran the LS 8.8 for 2 years before I added the E-Locker. For mild trail rides and mud it did well. Just apply a little brake pressure and I was moving again. Now, once I hit the rocks it was a no go as soon as a tire was lifted.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #10 of 35 Old 04-21-2010, 08:37 PM
ssyj94
My pos is the DD and ive had both a lockrite and detroit in my rear for over 6 years. I prefer the detroit hands down over the lockrite it doesnt click or bang nearly as bad. Its actually quite predictible. It all depends on how much you want to spend and if you can set up gears yourself. If you cant then get a powertrax no slip its the smoothest lunchbox locker I've dealt with.
My build:
ssyj94 is offline
post #11 of 35 Old 04-21-2010, 08:42 PM Thread Starter
danieljeep88
Thanks for all the comments, so if a tire liftīs the lsd wont be useful? What combination of lockers would you use? Being on a budget ...
post #12 of 35 Old 04-21-2010, 09:00 PM
KA24DET95
i found my Ected from a jeep place out in Arizona. I believe for right around $600 about 2 years ago. If i remember correctly they do 5.7 & 6.1 Hemi swaps for a decent price and they sell kits where you can do it yourself. IE:motor mounts, ecu's, and harnesses.
post #13 of 35 Old 04-21-2010, 09:08 PM Thread Starter
danieljeep88
I didnīt know about the Ected lockers I did some quick research I read good things, and it`s in 636$ I think I can wait a little more and go for it . Thanks dude !
post #14 of 35 Old 04-21-2010, 09:12 PM Thread Starter
danieljeep88
Thinking clearly itīs to much $$ haha....
post #15 of 35 Old 04-21-2010, 09:47 PM
burnout189
well according to what everybody else says, i must have been the "unlucky one" or somthing. but i will say that i bought an aussie for my 8.8, and replaced it with a detroit after about 2 weeks. i could not stand it. it banged popped pulled and pushed all the time. the detroit will occasionally give you a little reminder, but NOTHING like that aussie.
that being said, the detroit is great on a street driven jeep. i have absolutly no regrets with the detroit, except not using it the first time.
i would go detroit rear, selectable front. i cant afford the selectable yet, so fronts open until i can.
BARNHART'S AUTO REPAIR
burnout189 is offline
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 04:37 PM
Help please - Oil recommendation Coyotes97 TJ Wrangler Technical Forum 1 02-19-2010 04:06 PM
Recommendation(S) digizure YJ Wrangler Technical Forum 17 02-13-2010 04:16 PM
Need recommendation Mamas Jeep YJ Wrangler Technical Forum 10 04-02-2008 01:58 PM
Lockers in front, lockers in back biffstephens TJ Wrangler Technical Forum 30 12-04-2004 02:45 PM
