Rebuilt transmission concerns - JeepForum.com
post #1 of 6 Old 02-14-2002, 02:33 PM Thread Starter
damonejeep
I recently had my trans. over haulded. I have been driving it for 2 weeks now and the problem does not seem to be gone. Second and third gear were difficult and sometimes impossible to get into. For the first 10 minutes of driving, second gear is almost impossible to get into and third gear is difficult once in a while.
Is this normal for a rebuild tranny? Do I need to take it back?
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline
post #2 of 6 Old 02-14-2002, 04:14 PM
Bob K
Bob K's Avatar
That often happens after a rebuild due to the new gear oil being so thick. It gets easier to shift after the oil warms up and thins out. You can either:
-drive it for a while and see if it gets easier.
-replace the trans oil with ATF. this brings better shifting, but probably increased wear.
This is all assuming the rebuild was done right by a reputable shop. It wouldn;t hurt to aske them to test drive it and give an opinion.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 6 Old 02-15-2002, 09:45 AM Thread Starter
damonejeep
Thanks Bob K. ATF, I assume is automatic tranny fluid? What makes then different from manual tranny fluid? Just curious.
If I stick with Manual tranny fluid, will this difficulty perisit in shifting?
Thanks for the advice.
Andrew
post #4 of 6 Old 02-15-2002, 09:51 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
ATF is a thinner viscosity (10 - 20 wt.) than gear oil that is routinely 75 - 140 wt.
You may want to try running ATF for a month and as the trans breaks in, switch back to the recommended gear lube.
Steve
OldJeepguy is offline
post #5 of 6 Old 02-15-2002, 09:56 AM
JeeperJay
I just put in a rebuilt AX-5 tranny in my jeep and I'm having the same problems. Its quite hard to shift when its cold, but after a few miles it loosens up. The problem is definatly the fluid. Check your owners manual it may have a few fluid alternatives for warm and cold weather applications. If not then just change to a slightly lighter weight gear oil. And as mentioned earlier ATF is also a alternative but it may increase wear slightly in a manual tranny.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #6 of 6 Old 02-15-2002, 10:18 AM Thread Starter
damonejeep
Great. Thanks for the advice guys.
Andrew
Transmission does it need to be rebuilt? melcrim TJ Wrangler Technical Forum 0 06-23-2009 09:13 PM
My New Rebuilt Transmission bunkrdfool YJ Wrangler Technical Forum 13 09-18-2008 05:46 AM
AX5 Transmission New not rebuilt Canfourjeep YJ Wrangler Technical Forum 4 01-08-2008 08:00 PM
Getting my transmission rebuilt Barroom Hero TJ Wrangler Technical Forum 11 03-24-2006 09:54 AM
Please help me rebuilt an AX5 transmission wittymonkey YJ Wrangler Technical Forum 3 07-23-2004 07:39 PM
