Rebuilt 32RH Auto Transmission won't shift into 2nd or 3rd gear. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Rebuilt 32RH Auto Transmission won't shift into 2nd or 3rd gear.
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 11-13-2011, 10:29 AM   #1
Meisenslimer
I did a rebuild on a 1992 32RH auto transmission. I was having a major slippage on the upshift from 1st to 2nd gear. The clutch disks were burned and the friction material was pretty much gone.
After installing the transmission back in the jeep and refilling the fluids, I can' get the transmission to engage 2nd gear. Reverse and 1st work just fine, but it won't upshift out of 1st.
Fluids are full, everything else is running great. I adjusted the TV cable, but with no improvement.
Could this be related to band adjustment? I adjusted the bands to the FSM specs. If the front band was loose, would this be the symptom?
Any help is appreciated. It's my daily driver and it's been sitting in the driveway for over a week now.
Meisenslimer is offline   Reply With Quote Quick reply to this message
Unread 11-13-2011, 11:44 AM   #2
Spuznick242
From my expereince in the trans shop....if it doesnt work at all or in your case only part of it is working, its just a bad rebuild, adjustments only help not solve if you know what I mean.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2011, 08:30 AM   #3
Meisenslimer
Guess I'll be pulling the transmission again to go over the rebuild.
Any advice on what to look for? I double checked everything before I reassembled last time.
32rh , tf999 , transmission
