Rebuilt 32RH Auto Transmission won't shift into 2nd or 3rd gear. - JeepForum.com
post #1 of 3 Old 11-13-2011, 10:29 AM Thread Starter
Meisenslimer
I did a rebuild on a 1992 32RH auto transmission. I was having a major slippage on the upshift from 1st to 2nd gear. The clutch disks were burned and the friction material was pretty much gone.
After installing the transmission back in the jeep and refilling the fluids, I can' get the transmission to engage 2nd gear. Reverse and 1st work just fine, but it won't upshift out of 1st.
Fluids are full, everything else is running great. I adjusted the TV cable, but with no improvement.
Could this be related to band adjustment? I adjusted the bands to the FSM specs. If the front band was loose, would this be the symptom?
Any help is appreciated. It's my daily driver and it's been sitting in the driveway for over a week now.
Meisenslimer is offline
post #2 of 3 Old 11-13-2011, 11:44 AM
Spuznick242
From my expereince in the trans shop....if it doesnt work at all or in your case only part of it is working, its just a bad rebuild, adjustments only help not solve if you know what I mean.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #3 of 3 Old 11-15-2011, 08:30 AM Thread Starter
Meisenslimer
Guess I'll be pulling the transmission again to go over the rebuild.
Any advice on what to look for? I double checked everything before I reassembled last time.
32rh , tf999 , transmission
Auto wont shift out of park, BRAKE TRANSMISSION SHIFT INTERLOCK MECHANISM seems stuck Rivka TJ Wrangler Technical Forum 19 04-22-2012 09:26 PM
32RH auto transmission rear seal leaking mtrugger TJ Wrangler Technical Forum 0 09-13-2011 03:46 PM
My new 89 YJ 4.2L Auto stalls when I shift into gear. dovetail YJ Wrangler Technical Forum 22 03-08-2010 08:37 PM
32RH Auto Transmission Question....Does It Work Like a Manual Valve Body? blt4rox TJ Wrangler Technical Forum 18 10-20-2009 08:56 PM
shift kit for 32rh auto ?'s KKiowaTJ TJ Wrangler Technical Forum 6 01-08-2006 11:14 AM
